Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 03-25-2007, 03:20 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Question Head lube ;-)
Great title already. Quick question for my head rebuild.
-What's the stuff I need for lube? Is it RTX? Where can I get a lot of that at? Never seen it at AutoZone.
-My cams came with a small tube of Crower Cam Lube. Is this the same stuff?
-What exactly do I lube? Looks like everything right?
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 03-25-2007, 03:51 PM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Re: Head lube ;-)
My machinist gave me a little bottle of shit to use when I rebuilt my head. Well, that chinsy ass bottle broke before I even got home leaving green ooze all the hell over my head. I said fuck it and just coated shit up good with engine oil before I started it up, worked fine for me.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 03-25-2007, 04:24 PM
david-b's Avatar
Dave is THAT guy
Re: Head lube ;-)
But you still have to lube up the cams, valves, and everything.
75 Monte Carlo
Old 03-25-2007, 04:44 PM
Thor06's Avatar
Jizzed In My Pants
Re: Head lube ;-)
Oh yeah, I lubed the shit out of everything. Not so much on the head of the valves but I think I got a bit on the stem, made sure there was a bunch all where lifters and rockers were, all over the cam and where the are held to the head etc.
Old 03-25-2007, 06:15 PM
david-b's Avatar
Dave is THAT guy
Re: Head lube ;-)
So I there's one kind for everything though right? What's the name of it?
75 Monte Carlo
Old 03-25-2007, 06:39 PM
Thor06's Avatar
Jizzed In My Pants
Re: Head lube ;-)
Um, Mobil 1 10w-30? Thats what I used anyway.
Old 03-25-2007, 08:10 PM
david-b's Avatar
Dave is THAT guy
Re: Head lube ;-)
Not the oil... I think we're not on the same page here. I'll try to find what I think I'm talking about. Anyone else?
75 Monte Carlo
Old 03-25-2007, 10:11 PM
NateS's Avatar
NateS NateS is offline
Send a message via AIM to NateS
Re: Head lube ;-)
ARP sells lube. I believe its called molly lube. You need a lube that will stay on the parts and not run off like oil will. I lubed all moving parts and all cam journals with the molly lube(very generiously). After it was all together and right before I put the valve cover on I filled it up with oil straight onto the head parts. Just be carefull not to get any oil down the spark plug holes.
I believe I got my lube from www.extremepsi.com
95 GSX 5 speed
2.3L stroker bored .020 over
Built head
Bullseye/Borg Warner T04B 57 Trim Turbo
RNR 3" turboback w/ o2 eliminator
255 lph Extreme Motorsports fuel pump
Extreme Motorsports mbc
SAFC
Greddy Type S BOV
FMIC (core 28x10.5x3.5)
FIC 650cc fuel injectors
RK Sport Fuel Pressure Regulator
My Car Domain
Old 03-25-2007, 10:48 PM
Thor06's Avatar
Jizzed In My Pants
Re: Head lube ;-)
Yes Dave, we are on the same page. The bottle of special lube I got broke open so I threw the rest away and used regular engine oil for the assembly lube.
Old 03-26-2007, 01:49 AM
david-b's Avatar
Dave is THAT guy
Re: Head lube ;-)
That's not good. You going to have problems down the road with that thor?
75 Monte Carlo
Old 03-26-2007, 03:22 AM
Thor06's Avatar
Jizzed In My Pants
Re: Head lube ;-)
Why is that bad? Oh, and it doesnt matter, thats the engine that shit the bed less than 50 miles later.
Old 03-26-2007, 08:46 AM
tunedmotors tunedmotors is offline
Re: Head lube ;-)
Lube Everything!
www.findperformance.com
DSM Parts sites.
opcorn:
Old 03-28-2007, 12:10 AM
kjewer1 kjewer1 is offline
AF - Advisor
Re: Head lube ;-)
I use motor oil. These are some 40 years old v8s. Every motor I put together is fully primed the instant it starts up. That being said, I don't use assembly lube, just oil.
The only place I use a special lube is on the ARP head studs. There is a ton of info on my site about that however, so I won't go into it here.
It certainly will not hurt to use assembly lube on everything, so if you are anal and things like this give you a haahd-on, go for it.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 03-28-2007, 12:23 AM
steviek's Avatar
steviek steviek is offline
Re: Head lube ;-)
damn this thread topic name let me down jk
FP 18g turbo e3 o2 & mani, 3" exhaust, , 7 bolt, wiseco/eagle, walbro 255hp re-wired, Aeromotive FPR, FIC 1150cc, injen intake, greddy RS, aem wideband, turbo xs mbc, act 2600 clutch sprung 6 puck, BC 272's, dsmlink v2.5, ETS FMIC, Devils Own, JMF SMIM.
18 Inch chrome rims
In closet AEM Fuel Rail, SS Lines,
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
http://i83.photobucket.com/albums/j2...y/DSC00461.jpg
Old 03-28-2007, 12:22 PM
david-b's Avatar
Dave is THAT guy
Re: Head lube ;-)
Ya I'm going to lube it all up very generously. I'll be anal about that. Just want to make sure everything works fine. I don't want to have to go in to redo anything for awhile.
Quick side question. I've got the head bascially out together, just resting the pieces in there. The cams are just laying in their spots. Should they be able to spin freely, or will that not really happen till they get lubed up? They can turn, but they're really rough.
75 Monte Carlo
