Go Back   Automotive Forums Car Chat > Jaguar > XJ6| XJ8| XJ12 | XJR
XJ6| XJ8| XJ12 | XJR Classic and Current XJ Models, including the R series.
Old 03-25-2007, 03:10 PM
dpbrowne dpbrowne is offline
Cannot get rid of codes Help
1999 XJ8 92,000 miles. I keep getting the P1071, P0174 and P1000 codes. I changed the MAS sensor and it went off for about 120 miles but now it is back on. Where should I look next? Car is due for inspection in New Jersey. Need help fast.
Old 07-26-2008, 12:46 AM
djagman djagman is offline
Re: Cannot get rid of codes Help
mayby you meen p0171 system lean.check the plastic lines for the crankcase vent they allways get brittle and yes cause a system lean code!!!!!and it is so easy to check the intake gasket for leaks and to replace one is about 1.4 hours at best!!!
Old 07-26-2008, 12:51 AM
'97ventureowner's Avatar
'97ventureowner '97ventureowner is offline
Please check the date of the last post in the thread and do not respond if that date is longer than 3 months from the current date.
From AF's Community Guidelines:
POSTING IN CLOSED OR OUTDATED THREADS:
If a thread has been closed, there is probably a logical reason for it. If you feel that the reason(s) for closure of the original thread are unjustified or wish further clarification feel free to contact any member of the moderating team. However, do not start a new thread about another closed thread.
Please avoid posting or voting in outdated threads. It merely clutters up the message board and makes it more difficult for fellow members to sort through the vast amount of information contained on the boards. If you have new and important information to add regarding a past discussion, feel free to start a new thread and if need be, add a link to the original thread.
The link to these guidelines can be found here:http://www.automotiveforums.com/vbul...uidelines.html
Closed.
Thought for the Day… Alcohol does not make you fat - It makes you lean... against tables, chairs, floors, walls and ugly people.
If a prostitute here in America loses her job to a prostitute in India , is that considered "outwhoring"??-Jay Leno
" A Good Thing To Know"
