Hi there... I have an '87 Cherokee with an AW4 transm. on it and this is what happens.
P....... ok R....... ok N....... ok (D)..... No overdrive, it tries to engage but it loses it 3....... Only two gears (it's supoused to be 3 right?) 1-2.... Only one gear (it's supoused to be 2 right? Any ideas? I'm going worried , she is good I don't wanna lose it. Thanks in advance |
Re: AW4 Transmission shift problem
any vac. leaks?
Next issue...did you rebuild the NSS? |
Tip,,,,Mine is an '87 cherokee pioneer 6L 4wD 4.0 .Also I resenctly changed the motor mounts and transm. mount, may be that I messed something out. The linkage aligment,,, how to do it? Last edited by Raimundo; 03-27-2007 at 07:45 PM. |
I know there should be a vac going into the transfer case. not sure if your tear had it.
