Old 10-10-2002, 02:21 AM
mengy mengy is offline
Anyone selling a full dpfi -> mpfi kit
or know where I can get one? or would i have to get each part seperately?
Old 10-10-2002, 09:17 AM
Killa_CRX's Avatar
Killa_CRX Killa_CRX is offline
When Civics Attack!
HASport sells one for like $200
Although I think they require you to send them your core harness.
You can always check out their website at www.hasport.com and email them or somethin'
Honda Enthusiast
Old 10-10-2002, 11:26 AM
amy@af's Avatar
amy@af amy@af is offline
Traffic Directing Admin
Send a message via Skype™ to amy@af
e-mail [email protected] (jon). he's the best person to get used parts from
"hi! my name is Lady, and i'm a HONDA-holic"
..don't make me send Setanta over in his Waambulance to give you an aloe tissue for your sensitive nose!
*~ ~> USeR GUiDELiNeS*<~ ~*
I <3 the G Ride ~*~ I <3 OLD SKooL
Old 10-10-2002, 11:38 AM
Killa_CRX's Avatar
When Civics Attack!
What I'm wondering is, instead of converting the DX wiring harness to MPFI.... could you just take a MPFI harness out of an Si or EX and just transfer the whole thing over to the DX?
Don't think I've ever seen that option explored.
And I kinda wanna know, cause I can get my hands on a MPFI wiring harness real easily!
Honda Enthusiast
Old 10-10-2002, 12:18 PM
kris's Avatar
kris kris is offline
Off playing with fire.
I can get you the resistor box for $10 shipped. Also, I think there is a SOHC ZC intake manifold setup on Ebay.
Old 10-10-2002, 12:22 PM
1990civic's Avatar
1990civic 1990civic is offline
getting the si harness, is the only way i know how to do it!! the reason for that is because you need a new ecu, but if you have a std like i do it then you have to upgrade to a 5 speed tranny also, and after you add all that up, its just easier, and more economical to do a D16 engine swap!! Just My Opionion!!
Old 10-10-2002, 12:24 PM
91civicDXdude's Avatar
you should get the harness anyways for the fuel injector plugs and stuff. when i did my swap we had an entire MPFI harness but it would be 10 times harder to swap out the entire engine harness than to just extend a couple wires and run a couple more for the fuel injectors. you should keep the MPFI harness around for plugs, and it also works great if you just need a piece of wire *hack* *hack*
Old 10-10-2002, 12:58 PM
mdnnccivicrcr mdnnccivicrcr is offline
Does anybody know where to get a new MPFI harness? I sold my MPFI stuff and I'm trying to get it back, since I'm getting another A6 it'll have everything but a complete harness (stupid rednecks wont let me disconnect everything!) and I'm also missing the injector resistor pack
90 Civic EX *RIP*
90 CRX DX *RIP*
88 Civic DX Sedan (pushing boost) *RIP*
95 Accord LX Sedan
Old 10-10-2002, 03:01 PM
Whats the difference?
Old 10-10-2002, 03:31 PM
Killa_CRX's Avatar
When Civics Attack!
I would assume that using the Si wiring harness would mean rewiring most of the engine compartment, where as using the DX harness and just converting would, as the man said, mean only extending a few wires, running two extras for the injectors, and putting in the injector pins...
I would also assume (since I've never seen one) a MPFI ECU has the same shape port to plug into the wiring harness as does the DPFI.
In which case, converting from DPFI to MPFI doesn't sound like too hard of a thing to do... was just wondering if using the entire MPFI harness would be easier or not... but I guess not.
Honda Enthusiast
Old 10-10-2002, 04:13 PM
OldSchoolHatch's Avatar
OldSchoolHatch OldSchoolHatch is offline
Send a message via AIM to OldSchoolHatch
Why would you have to upgrade to a 5 speed transmission? I'm planning on doing the swap some time and I've talked to a bunch of people about it, but nobody said I'd have to do that! Are you sure?
Old 10-10-2002, 04:15 PM
dfarres's Avatar
dfarres dfarres is offline
Send a message via Yahoo to dfarres
u dont have to but with the SI tranny u get better performance & it's axles r stronger.
1993 Civic Coupe EX
1997 Chevy Suburban LT
“It's all fun and games - Until someone loses an eye"
Old 10-10-2002, 04:39 PM
kris's Avatar
There is the full MPFI setup on the parts trader for $90
Old 10-10-2002, 10:27 PM
1990civic's Avatar
well because you have to get an si ecu, which is made for a 5 speed, and the std, is a 4 speed, if you have a DX 5 speed then you might not need to!!
Old 10-10-2002, 10:31 PM
amy@af's Avatar
MPFI conversion info....
http://www.4thgenerationcivic.com/ho...conversion.htm
FS: DPFI to MPFI SWAP KIT sadiusomega Classifieds 0 06-30-2005 08:33 PM
dpfi to mpfi info needed slammed89civic '88 - '91 Civic | CRX | Wagon | Shuttlee 1 03-20-2003 06:52 PM
Pictures of wiring DPFI to MPFI?? bobbyd '88 - '91 Civic | CRX | Wagon | Shuttlee 24 01-30-2003 03:35 PM
dpfi to mpfi Bongnak '88 - '91 Civic | CRX | Wagon | Shuttlee 8 09-09-2002 02:56 PM
? year parts to swap DPfi to MPFi caneone Engineering/ Technical 0 08-01-2002 09:50 PM
