Old 03-25-2007, 09:00 AM
N3598C N3598C is offline
1989 Cherokee hard start
First start of the day, turns over fine, have ignition, then dies. Second start, turns over fine, ignition, and it starts fine and stays running, and ramps up to cold idle. Does this everytime, no start on first try. Fuel pump comes on with switch, and then shuts off as required. Installed new fuel filter, same issue. Its a straight 4-cyl, FI, 4wd, auto, 190,000 miles.
Old 03-25-2007, 10:30 AM
1996Chreokee 1996Chreokee is offline
Re: 1989 Cherokee hard start
On your next first start of the day... turn the key on so the fuel pump turns on ( but don t start the engine) then turn the key off... then start it like you would on your second attempt... Could be that the fuel pump is just priming on the first attempt and the second time it takes off... A sign of a tired fuel pump????
Old 03-25-2007, 11:02 AM
Thanks for the input. I'll try today.
Steve
Old 03-25-2007, 11:43 AM
Well, I tried the key-on test, fuel pump runs, then key back to off, then try start again. Still no start. On second start attempt, car starts , ramps up to cold idle and runs fine. Any more thoughts?
Old 03-26-2007, 10:21 PM
AlohaBra's Avatar
AlohaBra AlohaBra is offline
  1. Fuel pressure test using a gage
  2. CPS-crank positon sensor
  3. Battery voltage..test it
