Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 03-24-2007, 11:42 PM
exploreco97 exploreco97 is offline
Leaking front differential
My front differential is leaking and getting worse with time. My local repair shop told me that both half shafts have to be removed and the gasket needs to be replaced, which does make sense. Only problem is it is about $450 and money is kind of tight right now Anyone have any suggestions or is this about the only option? Thanks
04 Toyota Camry LE 87,000
07 Honda Pilot EX-L 59,000
Old 05-13-2007, 09:00 AM
dcmaynard dcmaynard is offline
Re: Leaking front differential
I have a 96 and it was leaking from the rear of the Diff. and I took it in and it cost somthing like $150. so I would check another shop.
Old 05-15-2007, 06:33 AM
denisb denisb is offline
Auto parts stores usually have aditives you can add to help stop leaks. I wouldn't recomend using it for long term as it might affect the oil structure of the existing oil, but it might be a short term fix.
