Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 03-24-2007, 06:50 PM
HHoover1874 HHoover1874 is offline
Electrical short
My dome lights, trunk, and door locks have gone out. my head lights have also gone out. I checked the fuses and they are all intact. I was driving, charing a phone, and they all went out. All fuses are good. Any clues as to where the short could be?
Old 03-24-2007, 07:28 PM
Blue Bowtie's Avatar
Registered Offender
Re: Electrical short
Welcome Aboard!
What year Caprice?
Old 03-25-2007, 09:56 PM
Originally Posted by Blue Bowtie
Welcome Aboard!
What year Caprice?
It is a 1990
Old 03-27-2007, 07:09 AM
Registered Offender
It's probably not a short, but an open circuit. I'm guessing that the key warning chime is also inoperative.
Do either the tail lights or instrument lamps work? If so, the likely problem is a fusible link near the battery or starter, or the connection for that circuit at the bulkhead connector.
Is there voltage at the large red wire at the light switch? If not, non of that will work.
Old 03-28-2007, 12:33 AM
I have break lights but nothing else. The dash board lights for seatbelt and starting are on, also. The key chime does not work, nor does the horn. Where would an open circut be? How could I trace it? Thanks.
Old 03-28-2007, 01:06 AM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
He wrote "Do either the tail lights or instrument lamps work? If so, the likely problem is a fusible link near the battery or starter, or the connection for that circuit at the bulkhead connector"
That's your two main areas to look for an open. The bulkhead connector is where the main harness passes through the firewall to the fuseblock under the dash. Sometimes, the bolt in the center (that holds it on) can work loose and cause all sorts of electrical calamities. Check there. Also, there are some fusible links that attach to the starter solenoid, to the battery lug. Check those to make sure they have continuity. You may need an ohmmeter to test the links, but they usually have a burned rubber appearance if they're done. My car, an '88, has three fusible links (they pass through a tube underneath the exhaust manifold on their way to the starter). Of course, if you do have a fusible link that's bad, you need to find out why before you fix it. They don't go bad out of the blue, or from old age.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 04-11-2007, 10:36 PM
Thanks for the suggestions, guys. The problem was the fuse linkage from the starter. I had it repaired today for only $42.00
Old 04-12-2007, 06:12 AM
bobss396's Avatar
bobss396 bobss396 is offline
Send a message via AIM to bobss396
Good find, a cheap fix to boot. Whenever you have an electrical problem that is wide spread like yours, look at the fusible links first. The links themselves are very inexpensive.
I've replaced the one by the starter on my '79 and the wire I was splicing it into kept deteriorating as I went along! But finally was able to get a good crimp splice on it and shrink sleeved it to ward off evil spirits.
Bob
