Old 03-24-2007, 03:10 PM
DRW1000 DRW1000 is offline
Brake On Off Switch
So I have been looking at some posts that indicate that one should check their BOO switch because there is a possible fire hazzard.
I think some have said it is available at Ford. Can anyone remember the cost?
Besides the Cruise not working are there any other signs?
Is this switch only for the cruise control release?
Is it a normally open switch that closes upon brake pressure or is it the other way around?
Thanks
Old 03-24-2007, 06:31 PM
wiswind wiswind is offline
Re: Brake On Off Switch
The switch should be under $20.
You can look and see if it looks damp......if so replace.
I posted pictures of the process, and it is super easy.
I bought a bottle of brake fluid just in case, but did not need it.
My Alldatadiy description says that the PCM uses the switch input for torque converer lockup, but I don't know if that is true........as I did not notice any drivability change with the switch working or not working.
Moderator for Ford Windstar room only
Links to my pictures, intended as an aid, not a replacement for, a good repair manual.
1996 3.8L Windstar
http://www.flickr.com/photos/4157486...092975/detail/
2003 Toyota Sienna pictures (not much there yet)
http://www.flickr.com/photos/4157486...781661/detail/
Old 03-26-2007, 11:17 PM
Wiswind,
I saw one of your photos but I guess I didn't look enough because I missed the procedures. I will check again.......................Thanks.
Okay I see now. Yes it does look easy. Does Fluid drip out of the brake resevoir when changing?
Old 03-28-2007, 09:47 AM
AvalonJohn AvalonJohn is offline
DRW1000,
A small amount will come out. About 1/2 oz. I just used a small plastic cup and held it under the switch as I unscrewed it.
AvalonJohn
Old 04-01-2007, 07:11 PM
garync1 garync1 is offline
Just replaced mine a few weeks ago. 20.00 at the dealer very easy to replace. The spring inside gets weak. I popped mine apart to see if i could some how fix. But just easier to replace than to go around and try to find a spring that may not work any way..The parts guy said the part number had been chnged a few times so that ment to him that they had some issues with it.. hope this helps...
