Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 03-24-2007, 12:57 PM
albarros73 albarros73 is offline
Does every Camry have keyless entry?
I just bought a 99 Camry LE. It has power locks but I don't know if I could buy a remote to use because I'm not sure it has keyless entry. I have been reading foruns about it and learned about ways to program the remote but my Camry doesn't have the black box with the green button under the driver's seat. I also found out that you can jump 2 terminals (#2 and #10) behind the mirror adjustment switch. I removed it to check and there are no wires coming of terminal #2.
Does anyone know how to check if I have keyless entry installed on it?
Thanks!
Old 03-24-2007, 01:35 PM
Mike Gerber Mike Gerber is offline
AF -Advisor
Re: Does every Camry have keyless entry?
"Does anyone know how to check if I have keyless entry installed on it?"
You can call Toyota corporate customer service at 1-800-331-4331 and give them your VIN number. They can determine from the VIN whether or not your car came with keyless entry.
Mike
Old 03-24-2007, 05:09 PM
Thanks! I called them and they said it has keyless entry.
Now I just have to find out how to program it. I already tried two procedures (that I wrote on my first post) and didn't have any luck. Does anyone know anything else I could try?
Thanks!
Old 03-27-2007, 04:10 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Here is a relevant post I found by Searching the FAQ Thread.
http://www.automotiveforums.com/vbul...6&postcount=15
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 04-01-2007, 08:18 PM
Onblsht's Avatar
Onblsht Onblsht is offline
Authorized Vendor
Have you verified if you have which of the 2 systems you have installed?
Factory installed = FCC: GQ43VT7T
Dealer/Port installed = FCC: BAB237131-022 (commonly referred to as RS3000 or VIP)
Replacement keyless entry remotes available here - up to 90% off -
All makes/models from Acura-Volvo, 1988-present -
http://www.OriginalKeyless.com
Old 04-02-2007, 01:12 AM
Thanks for the responses. After trying all the procedures I found online I came to the conclusion that my car doesn't have the keyless entry installed, even though Toyota's Customer Service representative told me that it had by phone. So I decided to go to a dealer and after checking it they told me that my car doesn't have keyless entry installed.
