Go Back   Automotive Forums Car Chat > Buick > Century
Old 03-24-2007, 10:38 AM
jjchevy jjchevy is offline
Question Low coolant light mystery
I have a 98 Buick Century the low coolant light comes on after the car has been sitting for a few hours or overnight and is first started. After the motor gets to normal operating temperature the light goes off. I checked the coolant level in the radiator and bubble when this happens and it is always full. The car does this everytime I run it after it has been sitting and every time as soon as the temp hits normal operating the light goes off it's like the thermostate opens and it triggers the sensor or whatever.
I tried putting the car on an incline and runnung it for 1/2 hour with radiator cap off until it started puking coolant out pretty stedily but the next day when I started it cold the light was still coming on.. I also tried bleeding the coolant at the 2 spots, one on the pipe on the fornt of the motor by valve cover and the one by the thermostat still no luck.
ANYONE HAVE A SUGGESTION?
Old 03-24-2007, 06:28 PM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: Low coolant light mystery
The sensor is usually located in the radiator. They get corroded and if removed and cleaned they will work properly. As long as the coolant is full then I wouldn't worry about the light.
Old 03-25-2007, 01:10 PM
Thanks for the tip gtpdad. Removed and cleaned sensor, problem solved....when will I learn to keep it simple. 156K on it now, I did change the dexcool but problem did not show up untill a few months later.
