Oil for 88 Camry
What weight of oil is recommended for an 88 Camry? Would 20/40 Penzoil be OK?
Re: Oil for 88 Camry
I'd use 10W30. Toshiro is no fool.
The manual for my 87 lists 6 different recommended viscocities ranging from 5w30 to 20w50 depending on expected ambient temperatures. They don't make it easy. For temps over 80 deg f use 20w50 or 10w50. For temps below 50 deg F use 5w30 or 10w30 or 15w40. 20w40 or 10w40 is for temps anywhere between. I live in a desert region and use 20w50 during the summer and 10w40 during the winter.
Just remember you want "thicker" oil in the summer and "thinner" oil during the winter. The higher the number the thicker the oil.
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds. **Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual. 07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan |
I have a 2004 Camry with an 2AZ-FE engine with 62K on it and was wondering if I would be better served with 5-30 synthetic or just keep using regular crude oil. Oil has never missed a 3K change interval so far. What does anyone reccomend?
Toyota now recommends 5W-20 synthetic for 2AZ-FE (sticky thread at top of forum):
http://www.automotiveforums.com/vbul...d.php?t=604788
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html "What we've got here is a failure to communicate" |
5W-20 it is
. At my next oil change I will start using castrol syntec more than likely.Thanks |
Evan Support your local volunteer fire department =============== My Rides: 2003 Ford F-350 Long Horn Hauler Others: 1999 Toyota Camry LE V6-Dad 2004 Chevy Tahoe Z71-Sister 2004 Toyota Camry LE V6-Mom |
What do you reckon caused it to start spraying oil everywhere? I have no leaks, and the engine is bone dry on the outside. All seals are excellent, etc.
I guess it's high milage. I also put it in 5w-30 and it leaked went to 10w-30 was better but it just used/leaked some. I went to synthetic blend and have no issues whatsoever. I think it was it's sudden change over. I guess i should have gone to synthetic blend first. Not sure really.
