Old 03-23-2007, 08:35 PM
bad3kgt's Avatar
bad3kgt bad3kgt is offline
Send a message via AIM to bad3kgt
Wheel bearing help please!!
Does anybody know a good guide for replacing the front wheel bearing ? I finally just got the 1" 1/4 bolt off the damn car and im stuck.....not sure what to take off next to get to the bearing.
==--92 Mitsubishi 3000gt SL--==
Mods So Far
JSpec Engine
3sx Stage I Clutch
3sx Downpipe
Unorthodox Underdrive Crank Pulley
Bomex Bodykit
18x8 Chrome rims
Old 03-23-2007, 08:55 PM
Twizted_3KGT's Avatar
Twizted_3KGT Twizted_3KGT is offline
Re: Wheel bearing help please!!
Which bolt are you talking about?
For the FWD bearings you need a press. They're press-in bearings. I believe there's special tools for it, but i've always used a press.
So if you have a press, or access to one, or have the special tools...you just have to take off the steering knuckle (remove tie rod, seperate ball joint, remove two strut bolts, and remove cv axle nut)
1997 Mitsubishi 3000GT VR4 - 269AWHP/290AWTQ (Mustang Dyno) - [email protected] - 1.756 60ft. - [email protected] (Best TDO4-9B Time) - Driver Mod - IPS TD04-19TL - SPEC 4+ - Wiseco Pistons - 3SX Custom Forged Rods - PMP FMIC + Much More.
Old 03-23-2007, 09:11 PM
bad3kgt's Avatar
The big nut in the center of the wheel, i took off the caliper and the rotor and then the huge inch and a quarter nut with the pin through the bolt.
Mods So Far
JSpec Engine
3sx Stage I Clutch
3sx Downpipe
Bomex Bodykit
18x8 Chrome rims
Old 03-23-2007, 09:35 PM
Ahh you said bolt in the first post, that threw me off. Yeah thats the axle nut i was talking about. So do you have a press to do this with?
Old 03-23-2007, 09:45 PM
bad3kgt's Avatar
nope =/
Mods So Far
JSpec Engine
3sx Stage I Clutch
3sx Downpipe
Bomex Bodykit
18x8 Chrome rims
Old 03-23-2007, 10:12 PM
nope =/
Well thats no good. Too bad you don't have a VR4, it's just a hub (bolt on).
Old 03-23-2007, 10:38 PM
bad3kgt's Avatar
dammit. now im gonna have to put it all back together and drop it off. Thanks anyways man.
Mods So Far
JSpec Engine
3sx Stage I Clutch
3sx Downpipe
Bomex Bodykit
18x8 Chrome rims
Old 03-23-2007, 11:14 PM
XeVeNskyLiNE's Avatar
XeVeNskyLiNE XeVeNskyLiNE is offline
Turbo makes me emo!
Send a message via AIM to XeVeNskyLiNE
Hey man, just order the whole wheel hub assembly. Its alot less hassle than having a new one pressed in. I've replaced 3 of them on my Eclipse, and I'd imagine the process would be very similar with your 3KGT. Oh and the answer to your question as to what you do after you get the axle nut off is to pull the axle itself out and you should have access to replace the whole wheel hub assembly if you go that way.
_______A-10 Aircraft Armament Systems Apprentice vv Can't get my sig right vv
Currently in Davis-Monthan AFB, Arizona MySpace My S14 and DSM
Old 03-24-2007, 07:21 AM
no. its not a hub bearing. I just got through explaining that. different cars, different setup.
Old 03-24-2007, 11:36 AM
Turbo makes me emo!
He's talking about a wheel bearing right, so its the samething as the hub bearing. Ofcourse the bearing is pressed into the hub, so I just thought you guys could just replace the entire wheel hub assembly. Sorry if i'm wrong.
Old 03-24-2007, 12:36 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Nope. On the SL's and bases its pressed in and you have to press it out. On DSMs and VR4s it bolts in.
Old 03-24-2007, 03:20 PM
Turbo makes me emo!
Ah ok, learn something new everyday. Hope the mechanics are nice to him on the labor costs.
