Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 03-23-2007, 05:44 PM
metalkiwis metalkiwis is offline
ignition switch woes
i am utterly clueless here and any help would be nice. i have an 85 caprice and when i turn the key, forwards or back, nothing happens. i have power to headlights and dome lights. nothing off the key works. so i get a new ignition switch. plug the wires into the harness and pull the switch and the radio and wipers, etc come on. i was mounting it back on the column and it stopped working. back to how it was. what did i do? can something be shorting out the ignition? and blowing out the ignition switch? they are so simple, i dont see how the switch could have just stopped working.
Old 03-23-2007, 05:58 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: ignition switch woes
how hard is it to turn the key?
There's a possibility that the rack inside the steering column might be broken. This is a die-cast zinc part and they do tend to fail. You will have to disassemble the steering column to replace it, if in fact that is the problem.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 03-23-2007, 05:59 PM
the key does turn as it usually does. and the bar to the switch moves fine.
Old 03-24-2007, 10:59 AM
Blue Bowtie's Avatar
Registered Offender
