Old 03-23-2007, 02:28 PM
ChemMan ChemMan is offline
O-rings inside fuel rail quick disconnects
Like the title says, I need replacement o-rings since the olds ones won't hold fuel pressure and are seeping fuel all over the engine. Local GM dealer here can't even find a part number for them. Anyone have any suggestions?
Thanks.
2010 Mazda CX-7 2.5L 12000 miles
2003 Chevy S10 Extreme 4.3L 57000 miles
1995 Buick Lesabre Custom 86000 miles RIP
2002 Pontiac Sunfire SE 130000 miles RIP
1997 Pontiac Bonneville SE 91106 miles Totaled by attempt to steal the car!!
R.I.P. 1978 Ford Fairmont 83000 miles
Old 03-23-2007, 02:33 PM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
Re: O-rings inside fuel rail quick disconnects
Did you soak them oil before iinstalling?
Old 03-23-2007, 05:59 PM
I didn't install new ones. The o-rings are original. I've had to remove the fuel rail a few times since I've had the car to deal with injector issues and to replace the manifold gaskets. I'm guessing that after all the removals and installations the o-rings have either dried out or I've damaged them somehow.
Old 03-24-2007, 06:44 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Click Here to see if this is the "O" Rings you are looking for. ACDELCO Part # 217452 {Sold Individually #22514722}
SEAL,FUEL FEED FRT PIPE(O RING) PART OF PIPE,FEED & RTN ASM BUNDLE-7.35MM ID X 1.66MM THK** Sold in packs of 10; Price reflects cost of each individual item, not the pack * View Image
Old 03-25-2007, 07:34 PM
Hmmm... Looks like it could be it. The description says it is for inlet and outlet, but the inlet and outlet are different diameters. However, my old man, the greatest parts guy in the world, found a dorman kit that should work part# 800-060.
Old 03-30-2007, 01:28 PM
pcmos pcmos is offline
Send a message via AIM to pcmos
Go to your local auto parts store and ask for HNBR O-Rings that are compatable with R134A refrigerent. The HNBR material is resistant to just about anything including gasoline. I replaced both sets of O-Rings on the fuel rail on my 00 LeSabre about 4 months ago with HNBR rings and they seem great so far, no leaks. They were extremely frustrating to pick out and replace, required lots of patience and a steady hand. The best part of using HNBR O-Rings is that most auto parts stores stock a large variety of sizes for people doing R12 to R134A A/C conversions, they're typically green or blue in color. If you research the HNBR material you'll find that it outperforms just about every other O-Ring material used, in my opinion, that makes it a perfect choice for just about any application.
