Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 03-23-2007, 01:33 PM
schellbd1 schellbd1 is offline
Stalling while slowing down
Hi I am hoping someone has experience with this issue. I own a 96 SL2 with 105K on it. On two seperate occasions on trips of over 30 miles of freeway driving as I go to slow down and come to a stop on the off ramp the car stalls out and dies. I can immediatly restart the car and it will idle in park but if I put it into drive it will stall and die again right away. After I restart the car the check engine light will come on as well. After sitting and completely cooling off for an hour or so it will start and drive just fine. the car seems to run perfectly on short trips. The dealership hasnt been able to replicate the issue so if any of you have any ideas it would be much appreciated.
Old 03-23-2007, 08:02 PM
yaz4real yaz4real is offline
Re: Stalling while slowing down
Your car has a OBD II system so if you had a check engine light, it has a stored code. Get the code by going to Autozone and repost the code here. Don't post what they tell you what the code represents.
Stalling like you have written could be solved by cleaning your throttle body. Follow where the fresh air goes. Taking that air intake housing off and opening the throttle and plate covering will give you an idea why it may be stalling... crud... use carb cleaner and a tooth brush. You will see some sensors near the opening plate especially the TPS.. throttle position sensor. Cleaning that area well may rid you of this problem but get the code and post it...
Old 03-23-2007, 09:46 PM
ksion15's Avatar
ksion15 ksion15 is offline
most likely cause, egr valve.
runner-up, torque converter.
if it has any egr codes, this is probably your problem.
torque conv. not very likely.
K.S.
Service Technician
Saturn of XXXXXX
ASE Certified
GM/Saturn Certified
