Old 03-23-2007, 12:53 PM
jalar67 jalar67 is offline
Fuse
I know where is located both fuse box but where is the electrical window fuse?
how many amp?
what's the name on the box for this fuse?
Old 03-23-2007, 01:22 PM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
Re: Fuse
not sure which fuse box, but there are 2. one is under the dash next to your left leg. the other is under the hood next to the passenger headlight.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 03-23-2007, 01:25 PM
Re: Fuse
I know that....
I just want to know where is the fuse for electric windows
Old 03-23-2007, 04:53 PM
Linebckr49's Avatar
Re: Fuse
#9, pink, 30A. see pic below.
93 3000GT base
Old 03-23-2007, 05:04 PM
liquidPunk's Avatar
liquidPunk liquidPunk is offline
Send a message via AIM to liquidPunk
Re: Fuse
Damn you linebckr! I was just about to say that!, without the diagram though haha.
1992 Mitsu 3000gt sl 5sp
- High flow filter - Pioneer head, dual 10's - H4 headlight conversion
- Throttle Body Spacer - The "For God's sake stop that infernal buzzing" mod
- LED "Snake Eyes" - Lightweight Crank Pulley
-More to come-
Your 3000GT is the 5095th out of 6964 . Only 41exactly identical
Bloody Knuckles from Changing Fuel Filter Crew Member #1
