Old 03-23-2007, 10:10 AM
91S10's Avatar
91S10 91S10 is offline
Send a message via AIM to 91S10 Send a message via Yahoo to 91S10
New Rims
So on Monday im Buying 4 15'' Si Wheels and tires off my buddy for $100
Just one question....will they fit perfectly like i know the bolt pattern will but will i have to cut anything or will they just fit perfectly. and another question......will I have any rubbing issues when i go around turns and stuff like that? thanks alot
Old 03-23-2007, 10:28 AM
FuLL BLown STD's Avatar
FuLL BLown STD FuLL BLown STD is offline
Send a message via AIM to FuLL BLown STD
Re: New Rims
i had 00 si's and i had no problem with rubbing..205/50/15 and my car was tucked
Old 03-23-2007, 01:21 PM
FrodoGT's Avatar
FrodoGT FrodoGT is offline
Re: New Rims
They will fit just fine, no problems with my 15" blades, and im dropped reasonably low.
Cheap, Fast, Reliable..Pick two
Current project:
Rio Red 91 hatch.
A6/Z6 build, Hondata S300, Tokico illumina/Ground Control.
"I'd rather run 12's on steelies than 15's on rotas."
Old 03-23-2007, 11:11 PM
91S10's Avatar
Re: New Rims
Ok did u have any problems with rubbing or speedometer problems??
My g/fs dad thinks that i will have so many problems with the tires rubbing, and the speedometer being off and I go look....2 of my friends have CRXs with 17s on them. they have no problems with rubbing or anything and of course they dont believe me lol. So i just wanted to know....Thanks alot guys
Old 03-23-2007, 11:19 PM
Re: New Rims
like me n Frodo said..no problems with rubbing..and any diff with the speedo wouldnt be too noticeable..if not at all. i did juss tell u my car was tucked and when i say tucked i had about 2 inches clearance from oil pan to the ground..no rubbing dude.
Old 03-23-2007, 11:31 PM
FrodoGT's Avatar
Re: New Rims
The speedo diff will all be in the size tires you decide to run. Use this and it will definitely help you find a set that will get your speedo right on.
http://www.miata.net/garage/tirecalc.html
For instance, on my transmission the stock tires were 195/55/15. Say I wanted to move up to a 17" rim. I would have to run a 205/40/17 and it would be .1% off of actual speed, which is miniscule and would NEVER be noticed. Its the final outer tire Diameter that will throw off your speedo, not the size rim.
Current project:
Rio Red 91 hatch.
