Old 03-23-2007, 08:46 AM
finishline finishline is offline
Fuel shut-off switch question
On my '92 F350 7.3 the fuel shut-off on the injector pump stopped getting power, so the engine won't start. Where is the fuse for the engine shut-off switch on this truck? I've checked the fuse boxes in engine compartment and in dash panel and everything there looks good! I finally had to use power from another wire in the harness that is switched on and off by the ignition key switch. But I'd really like to figure out why there isn't power to the correct wire so I can put things back together properly.
Old 03-24-2007, 10:49 AM
96Rivman 96Rivman is offline
Re: Fuel shut-off switch question
Check the passenger side kick panel it should be behind it. Just push the button to reset it.
Old 06-05-2007, 10:18 PM
bpp4040 bpp4040 is offline
if it isnt located in side the passenger kick panel then its located on the drivers side under the dash right behind the clutch or brake pedal on the fire wall
