Old 03-22-2007, 09:57 PM
acassell60 acassell60 is offline
2002 Grand Am troubles
Losing power while driving but wait a period of time the car will restart. Going for short runs and turning the car off than i have problems restarting the car, the ignition would turn over but will not start but again wait a period of time and the car will start.
Old 03-22-2007, 10:39 PM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
Re: 2002 Grand Am troubles
It would help to know what engine you have,
how many miles, deffinatly need more info
And Welcome to AF.
1999 Grand Am SS 3.4 OHV
Old 03-23-2007, 12:10 PM
Unhappy Re: 2002 Grand Am troubles
The engine is 2.2 l and it has 198,000 km on it. I've had some work done on it but still no better. Any ideas on what could be the problem would be great. Thanks for the help.
Old 03-23-2007, 09:49 PM
crazy Jim's Avatar
crazy Jim crazy Jim is offline
I had an ailing crank sensor cause a "no start when hot" I wonder if your problem may be a coil or some other ignition component becoming heat sensitive....
master airframe mech/shadetree auto mech/30+ years experience
current vehicles:
'02 Impala LS 3.8L
'02 Trans Am WS6 LS1 6spd
'99 Grand Am SE 3.4L
'71 Cutlass SX 455/TH400
'04 YZ450F
'07 Kona Garbonzo (dowwnhill mountain bike)
Old 03-25-2007, 09:14 AM
nightwolf86 nightwolf86 is offline
It might be your ignition switch. Not the ignition cylinder switch on your dash but the one under the hood. It runs about $60 - $80. I am not sure where it is located since the dealer put mine in for me, I do own the old one and the fingers are burnt and corroded real bad. My car would start when its cold outside but would take an hour of cranking to get it going in the heat. Hope this helps you out some.
The car I had this replaced on was a 2002 Grand am with the 2.2 ecotec.
Old 03-25-2007, 10:58 AM
Welcome to AF nightwolf86.
I believe you are talking about the ingintion coils,
they can act up when temps change and they are going bad.
Since its the 2.2 w/198k miles it could be several things in the ignition system causing this.
Gonna take some testing to track this down.
Good Luck acassell60
Old 03-29-2007, 05:55 PM
I love my grand am but Ive put alot of repair money into it lol.
I have to go get a recond head to put on, jumped time bad enough that it bent valves. The GM mechanics wanted $480 to take the motor apart to examine it. Head cost me $150, so knowing even a little bit about cars definetly saves money. If they wanted $480 for taking it apart, it probably wouldve been another 480 to put it back together plus parts and machining the head.
This car has a great powerful engine but man they can be a pain in the rear sometimes.
Old 05-17-2007, 06:08 PM
keenr's Avatar
keenr keenr is offline
I had what sounds like the same problem. Fuel pump is loosing pressure. I would be driving and the car would just stall for no apparent reason. Had the fuel pump changed and no problems since.
Old 05-18-2007, 12:12 AM
thiers many things that will cause your car to just stall for no apprearent reason.
But believe me thiers always a reason
Old 05-23-2007, 08:16 PM
kjkelsey kjkelsey is offline
I having kind of the same problem with mine. It started a couple of weeks ago. In the morning the car will start great. Then after setting for a few hours at work it crank but will not start. Used started fluid and it started fine. Now it will not start even with starter fluid. ANY SUGESTIONS PLEASE!!!!.
Old 05-25-2007, 03:05 PM
crazy Jim's Avatar
check for spark, check for fuel. need to do a little work first to narrow the options down below the 500 possibilities that currently exist....
current vehicles:
'02 Impala LS 3.8L
'04 YZ450F
Old 05-25-2007, 03:42 PM
Old 05-26-2007, 11:04 PM
Here is what has been wrong so far . The ignition control module was shorted, the battery negitive post was bad and the fuse junction box under the hood is either bad or corroded. The center section of the box will only give 6 volts once in a while and 12 volts once in a while . Looked at it last night but didn't really get to much into it last night but will work on it tomorrow. Thank you for the response everyone.
