Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 03-22-2007, 09:49 PM
kristen2218 kristen2218 is offline
Unhappy cutlass supreme cranks but wont start, HELP PLEASE
I just bought a 95 cutlass supreme 3.1 L 6cyl. The guy that we got it from said the motor was seized but it will turn over but not start. I dont know what is wrong with it. He said when it stopped running there was no symptoms it just died on the way home. he replaced the battery and starter and still nothing. I would like any suggestions on things to try, I dont want to have to replace the engine it has 100,000 miles on it. It did not leak any fluid when it stoped working. I dont know what else you need to know to help so if you need info ask. Thanks.
Old 03-23-2007, 03:45 PM
maxwedge maxwedge is offline
A990 racer
Re: cutlass supreme cranks but wont start, HELP PLEASE
Does the engine crank over on the starter, can you turn it by hand using a wrench on the crank pulley bolt, if so it it is not seized. First he said it was seized but then he says it will turn over? If it cranks, check fuel pressure at the rail, check for spark, see if it starts spraying carb cleaner into the intake.
Old 03-28-2007, 09:00 AM
sleber sleber is offline
It sounds a little fishy, first the engine is seized then it turns over but will not start. If you bought it thinking the engine was seized then you should have figured you were looking at engine replacement from the get go. Since the engine turns over you need to make sure you are getting spark an fuel. As mentioned previously, try spraying carb cleaner in the intake while cranking and see if it fires.
Old 04-01-2007, 09:21 PM
stompin60 stompin60 is offline
check the ignition module
1991 Trooper 2.8 yes it is red, and yes I have had the tranny rebuilt
