Old 03-22-2007, 09:09 PM
minimarshall minimarshall is offline
Fuel Problem
I have a 97 chevy silverado 5.7L 350 with new spark plugs fuel pump and filter and it stalled while goin over some train tracks. We replaced pump again after not turning on.. still nothing so we replaced the camshaft sensor and tested fuel pressure and its all good. we can poor a small amount of fuel in the intake and it runs for a sec. or two. What can i do?
Old 03-23-2007, 01:43 PM
2000CAYukon 2000CAYukon is offline
Re: Fuel Problem
What is the fuel pressure with ignition on and engine off?
//2000CAYukon
Old 03-23-2007, 02:08 PM
Re: Fuel Problem
its 62 psi
Old 03-23-2007, 03:02 PM
Blue Bowtie's Avatar
Registered Offender
Re: Fuel Problem
If the plugs are firing, I'd suggest looking at the connector at the injector pod.
Old 03-23-2007, 04:32 PM
Re: Fuel Problem
Originally Posted by minimarshall
its 62 psi
Pressure is good. Like Blue Bowtie said, you need to look at the injector pod.
There is an updated injector pod that converts from CPFI (Central Port Fuel Injection) to MPFI (Multi Port Fuel Injector). The MPFI kit comes with 8 injectors instead of just one.
//2000CAYukon
Old 03-23-2007, 07:43 PM
MyTOY's Avatar
MyTOY MyTOY is offline
Re: Fuel Problem
mine in dealer now getting the updated injectors....$750
03 WRX
Old 03-24-2007, 07:40 AM
flair666369 flair666369 is offline
Send a message via Yahoo to flair666369
Re: Fuel Problem
Does anyone have a link, or anymore info on what this upgrade exactly is?
Old 03-24-2007, 04:19 PM
Re: Fuel Problem
Our truck has a Central SFI system. Is that the same as the MPFI because this system contains 6 injector ports which is housed between the upper and lower intake manifolds. Could my problem be the powertrain control Module (PCM)
