Old 03-22-2007, 04:38 PM
ARK51294 ARK51294 is offline
front end parts
ok anyone know where I can get a kit that has everything for the front end rbuild on a 2000 cherokee, tie rods, sway, etc.... Thanks
Old 03-22-2007, 08:56 PM
AlohaBra's Avatar
AlohaBra AlohaBra is offline
Re: front end parts
Don't know about a kit...but I would only replace parts as needed.
Some of the parts are quite expensive, so it think a whole rebuild including ball joints and U-joints are going to cost a lot of buckers...
Start with a new steering stablilizer and a front end lube..
Old 03-22-2007, 10:57 PM
1996Chreokee 1996Chreokee is offline
Re: front end parts
what problems are you having to want to rebuild the whole front end...?
Old 03-25-2007, 01:22 PM
Re: front end parts
shaking above 50mph I already replaced the stablizer and new tires are balenced and aligned I am down to te tie rods next I reckon
Old 03-25-2007, 10:53 PM
vamc's Avatar
vamc vamc is offline
Re: front end parts
www.quadratec.com
Take a look
Old 03-26-2007, 10:05 PM
AlohaBra's Avatar
Re: front end parts
OK. ..alignment? Did you do a lift?
Edit: sorry, you said you aligned... What kind of tires are you using?
Old 03-31-2007, 10:38 PM
sector95 sector95 is offline
Re: front end parts
RockAuto.com
All the bushings, front end kits, etc. Excellent site with online catalog. I plan to use these guys when I R&R all the bushings on the front. Most of the suspension stuff is good, name-brand stuff; MOOG, Spicer or AC/Delco. They sell OEM and better replacement parts (not Hi-Po aftermarket stuff) and the prices are very good.
Good luck.
Mike
00XJ
Old 04-01-2007, 10:14 AM
AlohaBra's Avatar
Re: front end parts
What about the ball joints? Lube ball joints and tie rod ends and see if that makes a difference. Add a touch of toe-in (1/32 to 1/16 in.) and see what happens.
Have you checked the trac-bar...especially the upper end?
