Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
Old 03-22-2007, 01:22 PM
gherikill gherikill is offline
Squeaking sound from glove compartment
2003 Impala LS
There is an annoying squeaking noise coming from the glove box/ passenger side area. Most of the time i have the radio up and cant hear it but when i can hear it... ever little bump it does it. Any ides on what it could be?
Old 03-22-2007, 07:47 PM
Gems Gems is offline
Re: Squeaking sound from glove compartment
Mouse?
Go Mark Martin!
Old 03-23-2007, 11:01 AM
'97ventureowner's Avatar
'97ventureowner '97ventureowner is offline
Originally Posted by Gems
Mouse?
Don't laugh. It could be. Especially if the car has cabin filters in the back of the glove box to filter incoming air. On one of my Ventures, mice had eaten away at the filter material and were able to gain access to the inside of my glovebox. Not a very pretty sight, when I discovered it. They had started to eat at my invoices, and maps, etc., and left their little black "calling cards" all over the place. If you have inboard cabin filters in your vehicles, it is a good idea to check them regularly, especially in the fall and early winter as the rodents are looking for a nice place to stay.
Thought for the Day… Alcohol does not make you fat - It makes you lean... against tables, chairs, floors, walls and ugly people.
If a prostitute here in America loses her job to a prostitute in India , is that considered "outwhoring"??-Jay Leno
" A Good Thing To Know"
Old 03-24-2007, 02:36 PM
Any other suggestions? Could it be a spring in the passenger seat? It sounds like a squeaky mattress.
Old 03-24-2007, 03:40 PM
Many years ago a customer came into our shop complaining about the same situation. It turned out to be the "squirrel cage" attached to the blower motor had become loose and there was a wobble which made a squeaking type sound.
Old 03-31-2007, 11:30 AM
mediocre george mediocre george is offline
Actually, if it's happening going over bumps, I would check out the right front strut. If it's squeaking, it could sound like it's coming from the glove box.
Old 04-02-2007, 05:29 PM
WGP WGP is offline
Originally Posted by gherikill
2003 Impala LS ..
My 04 was doing the same thing ... turned out to be the glove box door... I asked my wife to hold the door while driving on a bumpy road and it stopped. I tried lubing the hinges and door contact points but it still squeaked .. It was only after I took out the excess weight (flash light and other stuf) that it stopped squeaking .. I had fogotton about it until reading this post ..
Bill
2003 2500HD LT Duramax CC SB 4WD,OilGuard BypassFilter, JK MegaFilter, LiftPump/PreFilter, Bilsteins, Retrax RollTop, J&J Millenuim Boards, Coolant Filter, Alli-deep-pan, High Idle, Mods UOA History
04 Impala, 99 Saturn SL1
Old 04-03-2007, 08:53 AM
Thanks I'll try moving stuff out of the glove department. I don't know how to check the strut or where to locate the squirrell cage.
Old 04-03-2007, 09:20 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
The squirrel cage is the impeller (fan blade) attached to the blower motor. When the motor bushings start to go, it will cause the impeller to wobble and vibrate or make a high pitched squealing noise.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 04-03-2007, 03:00 PM
Well I don't think it is the cage then because the car does not make a peep when it is not moving - Even with the fans on 5. On my drive home tonight I will empty the glove compartment and see if that helps - If not it is probably the strut. Anyone know how much a strut costs to fix?
Old 04-13-2007, 09:46 AM
I took everything out of the glove compartment and it still makes the noise. How would I go about checking the cage around the blower motor? The strut does not squeak if I physically push the car hood down.
Old 04-27-2007, 05:35 PM
breftayka breftayka is offline
mine does the same too, no idea what it is.
Old 04-27-2007, 06:00 PM
57chevyragtop 57chevyragtop is offline
Send a message via MSN to 57chevyragtop
Try rubbing a little petroleum jelly on the rubber bump stop(s) and use a crayola or candle wax on the latch mechanism...I had this an an older car and this solved it for me. It was a Lumina. My 02 has a rattle there somewhere I can't seem to get a handle on.
Old 05-01-2007, 02:09 PM
bloodyprice's Avatar
bloodyprice bloodyprice is offline
Send a message via AIM to bloodyprice
maybe its just a loose screw
Old 05-01-2007, 09:38 PM
zoemayne zoemayne is offline
outwhoring LMAO
