| Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible. |
rs turbo
1998 ecipse rs 2.0 DOHC
looking for a turbo kit. the cheapest i think that will fit is http://cgi.ebay.com/ebaymotors/420A-...spagenameZWDVW anyone have any advice if this will fit. also found this http://cgi.ebay.com/ebaymotors/420a-...spagenameZWDVW and the last one that i dont think will fit but is way cheaper http://cgi.ebay.com/ebaymotors/Eclip...QQcmdZViewItem any advice on the three?
GT2560r's, Nismo 615cc, ARP Head Studs, UD Pulley, SouthBend Stage5 clutch, 60mm TB's, Ash-spec Tune, Specialty Z 3" DPs, HKS intake, Energy Suspension, z1 Drive Shaft,E-fan, Port/Polished heads, AMS Manifolds, HKS SSQV BOVs, Howe Radiator, RPS segmented LW flywheel, UR OverDrive waterpump pulley, Billion Thermo, z1 silicone hoses, Stillen gauge pod w/autometers, D&S rotors all around |
Re: rs turbo
The 4g63 kit will not work. Wrong manifold. Piping will also be way different then. The first one looks good. You're probably not planning on running much boost so you don't need anything top of the line and major power. With any kit, piping will need to be cut, bent, or modified just a little to fit properly. When it comes to turbo kits, don't go with the cheapest. Espeically if it's an "eBay brand".
2013 Chevy Sonic 1LZ Daily Driver, 1.4L Turbo, 6spd 75 Monte Carlo SBC 400 6.6L, Aluminum heads, Hurricane Intake... 12 Chevy Sonic 1LZ 1.8L - Traded 01 Pontiac Grand Am SE - RIP 95 Eagle Talon ESi-T 5spd - RIP 88 Oldsmobile Cutlass Ciera- RIP |
Re: rs turbo
If you do get one of those ebay kits, chances are you will end up throwing away the turbo because they have high fail rates. Try and find an auction with everything except the turbo, and then get a good one from a vendor or a brand name one from a shop on ebay.
'92 3000gt SL Zoom Stage 1 Clutch Quote:
