Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 03-22-2007, 11:43 AM
hahapopcorn hahapopcorn is offline
clutch -.-
sorry i couldn't find a post to answer my question -.-
I have no idea whats wrong with my clutch (i don't think its quite slipping) The first 10 minutes or so of driving it is very difficult. sometimes some of the gears get blocked out. when i press the clutch it seems to be really soft and kinda drops really easily, also the gears get hard to get into and pull out of. but then after 10 minutes of driving or so it seems to be back to normal, the clutch is at normal pressure.
I also tried launching the other night and it woudln't just seemed to bog out then start off slowly (i think thats a whole new problem? -.-) i've been able to launch decently before =\
Old 03-22-2007, 07:57 PM
NOFX0617's Avatar
NOFX0617 NOFX0617 is offline
Send a message via AIM to NOFX0617
Re: clutch -.-
Have you checked your master cylinder and slave cylinder?
1998 Eclipse GSX
6 Bolt swap
MHI Big 16g
FP Race Manifold
Apex'i N1 Cat-back
Apex'i N1 Downpipe
Walbro 255 fuel pump
GReddy Type S BOV
Turbo XS Boost Controller
Balance Shaft Elimininator
ACT 2600
RRE 11lb No Name Flywheel
Prothane Motor Mounts
Tokico Illuminas Advanced Handling Kit
RRE Front and Rear strut tower bars
RMDSM Front and Rear Sway Bars
TRE Stage 2 Tranny
ARP Head Studs, Main Studs, Rod bolts
Old 03-22-2007, 10:32 PM
Plug-It-In Plug-It-In is offline
Send a message via AIM to Plug-It-In
Re: clutch -.-
Sounds to me like theres air in the lines...
Old 03-31-2007, 12:03 AM
Re: clutch -.-
update -_-;; i havn't had spare money to get the car checked out yet but now it's starting to grind when i get into 3rd and 4th gear every now and then. the clutch drops faster and is hard to get out of gear before it grinds when i try to put it in 3rd and 4th, but never grind in any of the other gears. can anyone take a stab at what could be wrong =\ the clutch fluid seems to be full and i don't see any leaks of any sort. i plan on getting it checked out next weekend but thought it may help to take a guess at what it might cost.
God I hope its not the tranny
