Go Back   Automotive Forums Car Chat > Volkswagen > Beetle - Air Cooled > Type 1
Old 03-22-2007, 09:22 AM
cbbond cbbond is offline
Point Gap Setting ; 36 Horse (VW Pickup)
Dear Forum Members:
I am replacing the rotor, points, and condenser (in distributor) on my VW Pickup (1958, 36 Horse, 6V) and need help.
Question 1: What is the gap setting for the ignition points (TDC) ?
Question 2: Will I need to set the timing as well?
Thanks,
Casey
Old 03-22-2007, 08:02 PM
BoatCop's Avatar
BoatCop BoatCop is offline
Re: Point Gap Setting ; 36 Horse (VW Pickup)
Point gap is set at .016. It's always a good idea to check/set timing whenever you do a tune up. Same with adjusting valves.
If it's the original distrubutor, make sure you get the right parts. Here's what the '58 P/U calls for: (Bosch Numbers)
Distributor: VW 211-905-205E, Bosch VJR 4 BR 8/1 (0231 129 019) > 211-905-205F, VJR 4 BR 25/1 (0231 129 010) > 126-905-205 (0231 178 009)
Can Use:
Condensor: 02 170
Rotor: 1237 332 072 (NLA) - Can use 04 008
Cap: 03 019
Coil: 00 001 (Blue Coil: 00 016)
Vacuum Can: None
Ignition Wires: 09 001
Spark Plug: W8AC
Timing Set At:: 7.5deg BTDC Static
Advance/Retard Range: Unknown
Alan
BoatCop
