Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 03-22-2007, 09:13 AM
4g63rice 4g63rice is offline
air/fuel signal?
i just wired up an air/fuel guage. the signal wire was to the passenger side kicker panel there is supposed to be a signal source there (like said on plymouthlaser.com), and it doesn't doesn't seem to be working to good right now. the lights move but it slowly moves up until it reaches the first couple green lights than it stops there. when it reaches the green lights, then it starts to respond to the throtlle a little by the lights moving realllllllllly slow up and down on the stoich section only.
do you guys think its my o2 sensor or should i wire it differently?
Old 03-22-2007, 10:37 AM
crunchymilk55's Avatar
crunchymilk55 crunchymilk55 is offline
Send a message via AIM to crunchymilk55
Re: air/fuel signal?
try tapping it closer to the ECU. look around, there are diagrams of how and where to do it. Then again, it's kind of a pointless gauge man...
now - 2000 civic
soon - 2002 is300
Old 03-22-2007, 04:15 PM
well, i needed a boost guage and it wont look to good with just one pod in the car. so i decided to get a dual pod. then i needed another guage, so i choose the air/fuel just so it will look cool and at least it will give me a reference of wat i'm running.
well i'll try to find a closer route and lets just hope it works!!
Old 03-22-2007, 04:50 PM
scottsee scottsee is offline
Send a message via AIM to scottsee
It looks pretty.. Much better looking then the ugly red numbers being spit out from my PLX M300..
DSM geek
Old 03-22-2007, 05:56 PM
yeah those are for the ricers. It doesn't even flash back and forth between red and green. How are you supposed to know anything from some stupid numbers?
now - 2000 civic
soon - 2002 is300
Old 03-22-2007, 07:15 PM
My point exactly.. I got riped off..
DSM geek
Old 03-22-2007, 07:45 PM
NOFX0617's Avatar
NOFX0617 NOFX0617 is offline
Send a message via AIM to NOFX0617
Yeah you should have gotten an EGT gauge instead...
1998 Eclipse GSX
6 Bolt swap
MHI Big 16g
FP Race Manifold
Apex'i N1 Cat-back
Apex'i N1 Downpipe
Walbro 255 fuel pump
GReddy Type S BOV
Turbo XS Boost Controller
Balance Shaft Elimininator
ACT 2600
RRE 11lb No Name Flywheel
Prothane Motor Mounts
Tokico Illuminas Advanced Handling Kit
RRE Front and Rear strut tower bars
RMDSM Front and Rear Sway Bars
TRE Stage 2 Tranny
ARP Head Studs, Main Studs, Rod bolts
Old 03-23-2007, 09:47 AM
How much is one of those?
Old 03-23-2007, 07:36 PM
NOFX0617's Avatar
Probably around the same price you paid for your Air/fuel gauge...they are sometimes called a Pyrometer...
1998 Eclipse GSX
6 Bolt swap
MHI Big 16g
FP Race Manifold
Apex'i N1 Cat-back
Apex'i N1 Downpipe
GReddy Type S BOV
ACT 2600
TRE Stage 2 Tranny
Old 03-23-2007, 07:39 PM
ned032002's Avatar
ned032002 ned032002 is offline
Originally Posted by NOFX0617
Pyrometer
I just got why they call it that
Old 03-27-2007, 07:09 PM
Does those pyrometer wire up the same like the one that i got?
(I have a autometer c2 guage)
Old 03-27-2007, 07:52 PM
C4 is better if we're going fpr Pyro's
DSM geek
Old 03-30-2007, 12:47 PM
i guess i need more research!!! lol
