| Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here. |
94 eclipse ground wires
hey guys. i need help to install aftermarket ground wires for a 1994 eclipse gs. i see the negative terminal, with the little fuse thing. but don't really know what to do about the stock negative cable. any help?
Re: 94 eclipse ground wires
can you explain a little more? Negative cable shouldnt have fuses i dont think, atleast my 92 talon doesnt? But if you could explain a bit more itd help out a lot
shouldn't it attach to the original location on the firewall? or are you talking about something else?
1992 Eagle Talon TSi AWD
sorry, didn't really mean to confuse you guys...but if you can give step by step instructing on installing the ground wires, that'll be cool...like can't really follow where all the ground wire goes too, but can i just cut them all off and install after market ones? iono, watever helps
Are you just using after-market ground wire kit? If so, you just connect the wires to a couple different locations around the engine bay. Basically, stay away from any positive (+) connections. Mine are as follows:
(-) Battery -> Firewall (-) Battery -> Head -> Block (-) Battery -> Intake Manifold (throttle adjustment plate to be exact) -> Firewall (-) Battery -> Transmission (-) Battery -> Alternator That is the correct order and placement. The only adjustment I made with the stock wires was cut the wire from the (-) battery to the firewall, and took off the stock wire from the intake manifold to the firewall and replaced both.
2013 Chevy Sonic 1LZ Daily Driver, 1.4L Turbo, 6spd 75 Monte Carlo SBC 400 6.6L, Aluminum heads, Hurricane Intake... 12 Chevy Sonic 1LZ 1.8L - Traded 01 Pontiac Grand Am SE - RIP 95 Eagle Talon ESi-T 5spd - RIP 88 Oldsmobile Cutlass Ciera- RIP |
Why do you need to install aftermarket ground wires? Unless you're running an extremely large system, the stock ones should be fine.
I know the stockers are fine, that's why I brought it up. I just don't want him ot get the notion that if he upgrades to aftermarket ground wires that he's gonna have an extra 20hp, because that's not going to happen.
no no..i understand im not gonna get an extra 20 hp gain or watever...for me, it's a passion thing. plus i want my engine bay to look cooler too...
ok, so i installed it, and now my battery light is on and the maintenace light is on too. wassup with dat? i know i stayed away from the positive. when i first turn the key, i can hear a buzz or sumthing also..you guys know wat's up? |
That's exactly the reason why I suggested against it, now you have a load of problems. You'll have to trace back and make sure everything is connected properly and the connections are tight.
Ahh nOObs. Take them all off. Then do one by one. Put it on. Check for lights and all. If fine, then go next. Always test to make sure its a negaive connection for connecting. That means pretty much anything, chasis, motor, whatever. Anything with a wire coming from someplace else, check it first. If you did the above directions, it would work fine.
You dont need no fuckin ground wires. Ground wires are for chicks and people with small weeners.
![]() Yeah, just take them all off and do like Dave said. |
