Old 03-21-2007, 09:19 PM
youngcaradvc youngcaradvc is offline
Trans Cooler and Misc Qs
Ive heard that one of the main problems with the ATX trannys is the heat it creates. So ive decided to purchase a tranny cooler, i found this: Hayden Transaver Plus transmission cooler kit, and just wondering if it is a good cooler or not. Another question, once i get new fliuds for the tranny and have it all tuned up i would like to put in the Translab shift kit, i noticed that this as been associated with a high stall torque converter. Just wondering why exactly i should get that and what it really does. Thanks.
P.S. my shift lock is still broken and i have no idea where to even look to fix it, if anyone knows more i would be interested in any info thanks.
Old 03-24-2007, 03:50 PM
Re: Trans Cooler and Misc Qs
No one? Okay
Old 03-25-2007, 10:32 PM
Hotshot8792 Hotshot8792 is offline
1. Unless you know what your really looking for, I would buy one of the tranny coolers from importperformancetransmissions.com
2. The shift kit allows your transmission to shift quicker therefore reducing the ability for something to slip between gears.
3. The high-stall torque converter raises the the rpm level where the torque converter allows the transmission to start moving. It also is built better allowing the transmission to hold more power.
4. You do not have to have both the shift kit and the high-stall torque converter installed together. They are completely separate of each other.
Daily Driver: 2004 Jeep Grand Cherokee Special Edition
1994 Mitsubishi 3000GT SL-TT Automatic - Black
3.05 L Arias Forged Pistons, Pauter Forged Rods, DR Stage 3 heads, 3SX TD05 kit w/ E16G's, CX Racing FMIC, 550cc injectors, Walbro 255lph pump, + supporting mods
1994 Mitsubishi 3000GT VR-4 - Black
Intake & Boost Controller so far
2006 Sea-Doo RXP Supercharged, Updraded SC, IC + supporting mods
Old 03-25-2007, 10:49 PM
OKay thanks, ill check out their website. Yeah i know that the shift kit and torque converter are seperate i just didnt know what the latter did exactly. Oh and if anyone knows where i can find code readouts online thatd be a help for me. Mr. Tranny said he couldnt get any codes off of the TCU but got some off of the computer for the engine i suppose.
Old 03-25-2007, 11:51 PM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
ATX TCU stuff is covered in the FAQ thread.
following those links in the FAQ, i found this page that has the TCU codes.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 03-26-2007, 12:02 AM
Yeah well he said he couldnt get any codes out of the tcu only the ecu i htink, somehting with a torque reduction and then somehting else. but thanks ill check more in depth.
