Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 03-21-2007, 05:29 PM
Andrewhuffman Andrewhuffman is offline
Camshafts
98 eclipse rs 2.0 DOHC
If i buy aftermarket camshafts, new valve springs and seats.... will this improve horse power, gas mileage, or will it just be the same?
Old 03-21-2007, 05:43 PM
steviek's Avatar
steviek steviek is offline
Re: Camshafts
Improving horsepower and gas mileage are not going to happen together. You either get one or the other most of the time. Depending on what grind cams you get you will get different results. Most of the time a grind like 272 will give you a little extra high end hp if thats what your looking for. I'm not sure about nt's though. But that mod is not a cheap one ripping apart the head is not a simple task and for the horsepower gains on a otherwise stock non-turbo will not be worth it in my opinion
also wrong subforum
FP 18g turbo e3 o2 & mani, 3" exhaust, , 7 bolt, wiseco/eagle, walbro 255hp re-wired, Aeromotive FPR, FIC 1150cc, injen intake, greddy RS, aem wideband, turbo xs mbc, act 2600 clutch sprung 6 puck, BC 272's, dsmlink v2.5, ETS FMIC, Devils Own, JMF SMIM.
18 Inch chrome rims
In closet AEM Fuel Rail, SS Lines,
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
http://i83.photobucket.com/albums/j2...y/DSC00461.jpg
Old 03-22-2007, 10:20 AM
Re: Camshafts
its getting a turbo in to mweeks, then the innnercooler a week after. clutch before the turbo, and a cold air intake.
Old 03-22-2007, 07:58 PM
NOFX0617's Avatar
NOFX0617 NOFX0617 is offline
Send a message via AIM to NOFX0617
Re: Camshafts
you will want to install the intercooler and turbo at the same time....
1998 Eclipse GSX
6 Bolt swap
MHI Big 16g
FP Race Manifold
Apex'i N1 Cat-back
Apex'i N1 Downpipe
Walbro 255 fuel pump
GReddy Type S BOV
Turbo XS Boost Controller
Balance Shaft Elimininator
ACT 2600
RRE 11lb No Name Flywheel
Prothane Motor Mounts
Tokico Illuminas Advanced Handling Kit
RRE Front and Rear strut tower bars
RMDSM Front and Rear Sway Bars
TRE Stage 2 Tranny
ARP Head Studs, Main Studs, Rod bolts
