Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse 2000+
Old 03-21-2007, 05:27 PM
only 205 hp only 205 hp is offline
Question Fuel Injectors?
My 2001 Eclipse GT ( auto) has over 85k miles and has been running fine up until now. I recently realized that when I come to a stop my cars revs go up and down, somtimes to the point where the car will shut down. Could it be bad fuel injectors or somthing more serious?...anyone else experience this problem?......one more thing, when i turn on the air conditioning the cars revs drop even more.....to the point where it dies down as well.
Old 03-22-2007, 10:57 AM
CamarosRsweet94's Avatar
CamarosRsweet94 CamarosRsweet94 is offline
Re: Fuel Injectors?
Does the car run rough? That may be something with the ignition system not working properly. It could be a fuel issue as well like bad injectors or a plugged fuel filter. Chances are you Idle Air Control Valve is bad and is causing the car to idle improperly. I would check that before anything else.
1994 3.4L Chevrolet Camaro - No more
2006 Hyundai Sonata
Old 03-22-2007, 12:52 PM
808drifter 808drifter is offline
Re: Fuel Injectors?
I'd think its the IAC. Have you changed your plugs yet?
Old 03-24-2007, 01:53 AM
rodbls's Avatar
rodbls rodbls is offline
Send a message via AIM to rodbls
Re: Fuel Injectors?
have you recently disconected your battery? If so, wait a few days and it should fix itself. As for the AC, yes your car will either loose rpm or gain rpm depending on certain conditions. This is because the AC belt takes a lot of power to turn, so the motor either under/over compensates for it and your revs change.
2000 Fed. Spec GT-"Lafawnduh"
Mods: SPEC 2+ Clutch, Fidanza Flywheel, PowerStop Rotors, Red Stuff Pads, Stainless Brake Lines, B&M Short Shifter, Energy Suspension Shifter Bushings, Deyeme Firm Motor Mounts, KYB AGX shocks with Eibach Proline springs, Halo Projector Headlights with HID 12000K Conversion, TYC Carbon Tails, Kicker SS6.5 Component Front, SS MB8 Custom rear, Tsunami 2F Capacitor, ***New Stuff*** JVC KD-AV7010 In Dash DVD Player, Kicker L7 12" Woofer, Kenwood KAC-X10D Mono Amp
Old 03-27-2007, 11:28 AM
WpBoosted3g WpBoosted3g is offline
Re: Fuel Injectors?
6 days late.. but what it could be.. if your stock..
1.check your car for any vac leaks... or if any of the vac lines are cracked/leaking or loose.
2. there like someone above it could be your IAC check it out.
3. carbon build up in either the MAF or TB you MAY have to clean it out.
4. have you changed you plugs lately?
