Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 03-21-2007, 05:25 PM
Andrewhuffman Andrewhuffman is offline
Car runs with no key
Tis be a 98 eclipse rs 2.0 DOHC
it starts and runs fine, but to turn off the car, i have to put it into gear and stall out. why is this? while the car is running i can take out the key and still drive, but the steering locks up when that happens. is there a ground wire in the ignition thats cut? pics are most helpful
Old 03-21-2007, 06:32 PM
crunchymilk55's Avatar
crunchymilk55 crunchymilk55 is offline
Send a message via AIM to crunchymilk55
Re: Car runs with no key
ground got messed up somewhere.
same thing happened to me, but I had to turn the headlights off to turn the car off. It's tedious, but start checking the wiring, two wires are touching somewhere or the ground is bad.
now - 2000 civic
soon - 2002 is300
Old 03-22-2007, 10:24 AM
weird that you mention the headlights because, a shop installed aftermarket headlights and only the regular lights work when i turn on the high beams. if i turn offf the high beams the regular lights go offf.... if that makes any since to you.
Old 03-22-2007, 10:35 AM
take it back to the shop and tell them to rewire everything. I would bet if they messed up doing something as simple as wiring headlights, they were bound to mess with other wiring in the area...
now - 2000 civic
soon - 2002 is300
Old 03-22-2007, 10:38 AM
i looked at the wireing and it look like it was done right,... but im not sure if the car did that with the headlights before. its a friends car, and he modded it before he even got to drive it... so ill have to ask him.
