Old 03-21-2007, 02:36 PM
BVC500 BVC500 is offline
Gluing photoetch parts together
Do you use C/A glue to glue photoetch parts, such as all the parts to a brake disk, together? Isn't it a bit thick?
Old 03-21-2007, 02:50 PM
MPWR's Avatar
MPWR MPWR is offline
Image Hosting Exceeded
Re: Gluing photoetch parts together
It all depends on how strong the bonds need to be. There are many, many ways of gluing PE together, each with advantages/disadvantages. If it has to be strong, CA or epoxy are the way to go. If not, white glue, acrylic clear gloss, or (my favorite) Microscale foil adhesive work great.
I'm guessing PE brakes don't need to be all that strong, but I've never used them. What do you think?
PHOTOBUCKET SUCKS
Old 03-21-2007, 02:59 PM
klutz_100's Avatar
Clear nail varnish also has it's uses with PE parts I have found (and my nails look pretty afterwards, too)
Old 03-21-2007, 03:38 PM
bhop73's Avatar
bhop73 bhop73 is offline
Eh? What kind of glue are you using? The CA glue I use. (Zap CA+) isn't thick at all...
http://www.bhop73.com/
Old 03-21-2007, 03:42 PM
gionc's Avatar
gionc gionc is offline
Authorized Vendor
Just a bit of solder, liquid acid seaming solution, flame seamer if only PE and iron seamer if on white metal, CA on plastic.
gio
Old 03-21-2007, 05:18 PM
DVST8R DVST8R is offline
I've only ever done p/e to plastic, for pieces with a good surface area, just used white glue. For tiny parts like rivets just use clear paint.
Old 03-21-2007, 07:47 PM
Yeah, I meant P/E to P/E. Thanks guys!
