Old 03-21-2007, 09:17 AM
pchop pchop is offline
Cam Sync Noise
just wondering if anyone has had luck with spraying lube in the cam sync for the noise and how long it last. what kind of lube is being sprayed probably something with teflon. thanks for replies.
Old 03-21-2007, 04:41 PM
Millermagic Millermagic is offline
Re: Cam Sync Noise
What year, engine?
- Leather - Transmission Cooler - Gen III Tweeter Sails - Gen III Rocker Covers -
As you walk through the valley of RICE, you shall fear NO V-TEC, for torque is with thee!
Old 03-22-2007, 09:24 AM
Re: Cam Sync Noise
2003 ford taurus 3.0 vulcan thanks keith
Old 03-22-2007, 11:06 AM
Willyum Willyum is offline
Re: Cam Sync Noise
I wouldn't fool with it, just change it. I bought my part at a local independent parts store for $99, got the instructions on the Tauruscarclub.com site. Takes 2 to 3 hours if you take your time.
The old part doesn't seem to be seriously worn but does make a creaking noise when you spin the shaft.
I've heard you can get one as cheap as $40 from Rockauto.com.
Old 03-23-2007, 09:07 AM
mrflint mrflint is offline
Re: Cam Sync Noise
I replaced my cam synchronizer with Rock auto part, was slightly oversized. I suggest you search for all postings for cam synch, there's plenty of advice. My part was easily sanded down to fit, your's might be OK. Mines has been running fine for 4 months. Part came with cam sensor and cam synch alignment tool for the $40. Once I got past the part fit, everything was fine.
When I got old part out, it was hard to turn by hand, bad bearings. If your holding in hand, you might as well replace it.
Old 03-23-2007, 12:56 PM
Re: Cam Sync Noise
thanks for all replies, much appreciated
