Old 03-20-2007, 10:35 PM
PlayStation3 PlayStation3 is offline
battery question
hi, i have a question, is there a way that i can get just a starting battery for under the hood and a deep cycle in the trunk and be able to isolate the starting battery from the deep cycle so that i dont have to hope that i can start my car and i want the deep cycle to be connected to the alternator also.
main reason i am asking is that the deep cycle that i want does not fit under the hood.
Old 03-21-2007, 04:35 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
Re: battery question
yep, it's called a battery isolator
Old 03-21-2007, 05:29 PM
yea after i made this post i firgured out that i wanted it isolated so i firgued that was what i wanted.
when i try to find one i see that they are rated my amps is that including the amount the engine needs or just the assorieys(sp)
Old 03-22-2007, 05:26 PM
Audio Guy
I have never used one but I can only assume it is rated by the amps of the battery (or load) that is being isolated
Old 03-23-2007, 06:28 AM
ok also isn't wiring in parall the same or is that when you have to use the same type of batterys
Old 03-23-2007, 05:39 PM
Audio Guy
well, essentially you are wiring parallel - just that there is a box between the two positive posts
Old 03-23-2007, 06:32 PM
ok i think just one more thing if i got the biggest HO made for my car and it is not enough still if i used the second battery for all the amps and that will make it so that the starting battery does not have to due with the stress because the alt will not be able to recharge compeletly(sp) now if the second battery drops to low in voltage it won't take it from the starting battery right. that is the main reason i kinda of want the isolator
Old 03-24-2007, 03:41 PM
Audio Guy
I think the starter battery is protected by the isolator, but I am not sure what happens if the car is on.
Old 03-25-2007, 03:01 AM
ok thanks
