Old 03-20-2007, 09:53 PM
northcountry northcountry is offline
iac
I have a 92 ga throwing code 35 witch is the idal air control changed it twice new o rings both times still throwing code and rpms fluctuating sounds like it wants to die speeds up and slows down any ideas
Old 03-20-2007, 10:40 PM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
Re: iac
Welcome to AF.
Did you clean the port that the IAC goes into?
IF not clean it out with TB cleaner.
Did you set the pintle on the IAC to spec?
You dont want to push or pull the tip this can break it.
Also make sure all the vacum lines are connected and not leaking causing the idle to fluxuate.
Hope that helps.
1999 Grand Am SS 3.4 OHV
