Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 03-20-2007, 08:02 PM
royboyz royboyz is offline
Is it difficult to change a fuel injector on a V-6
Can anyone give me insight on changing a fuel injector on a 1990 camry V-6? I think I narrowed it down to bad fuel injector on cylinder #3. From what I can see thats probably the hardest one to get to. Can it be done without removing the intake? Thanks..........Royboyz
Old 03-21-2007, 11:27 AM
davemac2 davemac2 is offline
AF - Advisor
Re: Is it difficult to change a fuel injector on a V-6
If it's one of the back ones, I believe you need to remove the intake plenum in order to remove the fuel rail and ultimately the injector directly underneath. The removal of the intake plenum is a little intimidating the first time, but you can probably do it within 1.5 hrs. Take some photos of the vacuum lines, etc before disassembling and maybe use a labeller. You will have a fairly sore back doing all this though! Probably good to wear a back support belt when you do it. The plenum to head gasket is metal and I think can be reused if you want, but do inspect it thoroughly. While you have the fuel rail off, it may be a good idea to replace all the injector o-rings.
dave mc
Old 03-22-2007, 09:20 PM
gen3-tony gen3-tony is offline
yes to everything dave says!
also, if it has 8mm allen bolts like my 93, be very careful. when you remove them, don't pull them - break them loose in one hit if you can. i didn't know any better and chewed up one of mine and had to use a bolt out to remove it.
tony
