Old 03-20-2007, 07:54 PM
flatblackratrod flatblackratrod is offline
Arrow tail light fuse/ small missfire
I have a 88 crx dx automatic. ok i have a couple of questions here first and probably the easiest my fuse for my tail acc. and dash lights keeps blowing i cant figure out what it is. Does anyone know anything i could try? Also I have started to notice a small backfire when accelerating. I have replaced the fuel pump recently and at the same time i changed the fuel filter. I have also changed the plugs. If anyone has any knowledge greater than what I have it would be much appreciated.
Thanks flatblackratrod
Old 03-20-2007, 09:52 PM
CRXperiment's Avatar
CRXperiment CRXperiment is offline
Re: tail light fuse/ small missfire
Sounds like you have a wire shorting out somewhere. For the bogging, maybe check your timing.
1989 Civic STD - sold
1991 CRX Si - current
Free Service Manuals: http://hondatech.info/
Old 03-21-2007, 06:45 AM
91S10's Avatar
91S10 91S10 is offline
Send a message via AIM to 91S10 Send a message via Yahoo to 91S10
I'm having the same problem with the lights. I got a quick fix for it. It will probably work for a while then just randomly blow a fuse again..
Buy that electric connection cleaner and clean all your light sockets out with a rag. Make sure you wipe them out good. Also if you can take a little piece of sandpaper and sand the inside of the connectors and the metal part on the light bulb. just be sure to blow out the leftovers before you put the lights back in.
This usually works for me, untill i actually get a day off to try and find the short in my car lol
Hope this helps
Old 03-21-2007, 01:15 PM
Usually a common place that causes your interior/ parking light circuit to short out is your front corner light bulbs. Pull off your corner lights, take out the bulbs and scrape the socket with a sharp object. After that wack it a few times and rub electrical grease in the socket before installing the bulb. This usually helps alot of our cars.
Old 03-21-2007, 06:10 PM
91S10's Avatar
I did not know that lol, i will have to try that one out someday
Old 03-21-2007, 08:50 PM
ya thanks guys i'll try all that stuff. Didn't even think to check front corners. Does anyone else have anything on the misfire problem?
Old 03-22-2007, 04:22 PM
livinincalifornia livinincalifornia is offline
Send a message via AIM to livinincalifornia
this might sound weird but I had the same problem and it was a connection behind the heater/airconditioner control thing. I just wiggled the wire around back there because I noticed the day before it went out that one of the lights back there wasn't glowing and the fuse stopped blowing and all the lights came back on
Old 09-25-2007, 12:34 PM
Serveck Serveck is offline
i am having this exact same problem, even with the idle, i have changed my flasher relay, dimmer switch, checked all the lights, and most of the other circuits, where else could it be shorted out? i even checked the haynes manual wiring diagrams and i am still stumped, any places i should check now? i got my turn signals to work for a while there, but now they will not work at all, they are not blowing a fuse, but just do not do anything, could it be the multi function switch on the side of the steering wheel? i really need tail lights to drive at night, and i kind of need turn signals, the #8 fuse blows instantly (even a 15 amp) as soon as i turn on the lights. thanks
