Go Back   Automotive Forums Car Chat > Chevrolet > Cavalier > Non-Performance
Non-Performance This is the place to discuss interior, exterior, and other non-performance related modifications.
Old 03-20-2007, 05:41 PM
02'CAVI 02'CAVI is offline
Stereo Shutting Off
OK, I JUST GOT A 2002 CAVAVLIER, ITS THE BASE MODEL, NO ONSTAR,OR XM,
OK.. THE FACTORY STEREO WOULD SHUT OFF GOING DOWN THE ROAD , OK I INSTALLED AN AFTERMARKET STEREO, USING A REGULAR WIRING HARNESS, SUBS, AMP..ETC.. NOW THE NEW RADIO IS STILL SHUTTING OFF FOR NO REASON, DRIVING DOWN THE ROAD... I'VE HEARD ABOUT A RADIO SHUT OFF DELAY? IS THIS A FEATURE THATS ON THIS TYPE OF CAVALIER, AND IS THAT WHATS SHUTTING THE RADIO OFF STILL? AFTER ALL THE LABOR OF TAKING THE DASH APART, CAN ANYONE HELP ME FIX THIS??
Old 03-20-2007, 10:49 PM
Derk_eliso's Avatar
Derk_eliso Derk_eliso is offline
Send a message via AIM to Derk_eliso Send a message via MSN to Derk_eliso Send a message via Yahoo to Derk_eliso
Re: Stereo Shutting Off
I've taken it apart like 30 times, feel my pain, lol... my stereo shuts down if it's too loud...
Old 03-21-2007, 03:12 AM
01Cavy 01Cavy is offline
Send a message via AIM to 01Cavy
I'm not quite sure why your radio is shutting off on it's own. Maybe a loose fuse. The delay shut off is when you turn your car off the radio stays on for I believe it's 10 minutes before shutting off unless you open either the driver or passenger door. Once the car is off and the doors are opened it will shut off, otherwise it will stay on for 10 minutes. Back to your problem, check your fuses, also check to make sure you have a good ground and no loose wires.
2001 Toyota Celica GT
Check out my CarDomain at...
http://www.cardomain.com/ride/2493960
Old 04-14-2007, 01:36 PM
gtekman gtekman is offline
I have the exact same problem in my 1998 Sunfire...If anyone knows how to fix this problem that would be greatly appriciated.
Old 05-26-2007, 12:12 AM
jjh1976 jjh1976 is offline
im having the same problem with my 96 sunfire
Old 06-04-2007, 05:31 PM
95sunny013 95sunny013 is offline
same problem with 95 sunfire very annoying....mostly when i shift or hit bumps....anyone know what do?
Old 07-17-2008, 03:55 PM
nigga018 nigga018 is offline
Same here...I installed An aftermarket radio...hooked up a 4400 watt amp and 2 10" dual coil kicker cvr's... my radio would shut off all the time, barely adding volume, and my car wouldn't start...so i charged my battery...i charged it for a whole day...next day i turned on my radio and it didn't shut off...i believe my battery didn't have any energy...maybe thats a reason?
Old 07-19-2008, 05:50 PM
GoHeels222 GoHeels222 is offline
Send a message via AIM to GoHeels222 Send a message via MSN to GoHeels222 Send a message via Yahoo to GoHeels222
That sounds like loose wires/bad ground. Take the cd player out and check the harness and every wire for a loose one..and when u put it back in make sure no wires are getting pinched, or anything similar to that. Its a tight fit with all those wires and an aftermarket cd player.
2002 Cavalier LS Coupe 5 Speed..
