Old 03-20-2007, 04:49 PM
persuazion persuazion is offline
Suds coming through bottom ac vents when in car wash with ac on....
What is going on? I have been having a waterleak when it rains for months now come through the bottom of the console,but today when I was going through the carwash I had my ac on and the 2 vents on middle bottom of the console stated blowing bubbles and car wash suds was streaming out of them...how could they get into the vents like that??? I posted the question about the water leak awhile ago with no help,but maybe this will give some clues as to what it could be...
Old 03-20-2007, 05:38 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Re: Suds coming through bottom ac vents when in car wash with ac on....
You need to clean & open the AC box drain. The AC box is located on the firewall and the drain tube is on the bottom. Any mechanic should be able to locate & clean it for you.
Old 03-20-2007, 09:26 PM
Ok thanks,do you have to take the cowling off to see it?Can I do it or should i just get the mechanic to do it?
Old 03-21-2007, 09:49 AM
HotZ28's Avatar
AF Moderator Elite
The only way to access the drain is from underneath the car. It would need to be jacked-up enough to crawl under the car about midway. Of course, a lift at the shop would work better.
