Old 03-20-2007, 03:17 PM
typerx7 typerx7 is offline
Erratic Idling
As many people as possible, tell me what the symptoms of an erratic idle can be.
My car is idling erratically, up and down around 2 grand back down to 1 grand. The throttle sticks a bit and I pulled off the TB and the plate is sticking itself, no the sensor. When it is very rainy out my car makes a noise and drives like the clutch is going bad (just replace under 16,000 miles ago w/ ACT and new tranny) I know it can't be the clutch because it makes the same noise and revs the same when it is "idling". I ve cleaned the entire intake system, intake utbe, TB, valves, etc. and still erratic idle. Possibly a sensor issue, but no check engine light. Im stumped.
What all can cause an erratic idle?
Old 03-20-2007, 08:07 PM
CRXperiment's Avatar
CRXperiment CRXperiment is offline
Re: Erratic Idling
Did you clean the iacv valve? Try bleeding you coolant and if that doesn't work then try to screw your idle screw in then back it out at 750 rpm.
1989 Civic STD - sold
1991 CRX Si - current
Free Service Manuals: http://hondatech.info/
Old 03-20-2007, 08:16 PM
Re: Erratic Idling
Done and Done, still nothing.
Old 04-02-2007, 04:38 PM
Re: Erratic Idling
replaced the IACV, still nothing,.
Old 04-04-2007, 06:34 PM
Re: Erratic Idling
The problem has been fixed woooooooot!!!!
I replaced the gaskets between the TB, the entire TB, w/ map sensor and TPS. problem solved. everything runs great now.
