Old 03-20-2007, 01:39 PM
ANTHONY2314 ANTHONY2314 is offline
97 Taurus overheating
Just purchased a 97 taurus 3.0 6c DOHC. Car overheats with in 12 blocks from cold start. Had 2 shops check out but neither knows. Dash says low coolant and service engine light comes on occasionally. Waterpump is good thermosat is good no leaks in lines or radiadtor. Radiator doesn't appear to be blocked. after putting in 3/4 gal of coolant and running it for 12 blocks it cools down and needs another 3/4 gal. again and again. Where is the coolant going?. Oil is good and clear no engine knocking or anything telling me its a head or head gasket please help
Old 03-20-2007, 01:55 PM
2.2 Straight six's Avatar
2.2 Straight six 2.2 Straight six is offline
That thing got a Hemi?
Send a message via AIM to 2.2 Straight six Send a message via MSN to 2.2 Straight six
Re: 97 Taurus overheating
is there white smoke from the exhaust?
if there is, your head gaskets gone and your cylinders and burning/steaming the coolant. if it's not that, there's a leak somewhere.
Seatbelts Saved My Life
Old 03-20-2007, 02:12 PM
No white smoke. Engine is very smooth sounding no mix of water in the oil both mechanics agreed that they both think there is no internal problem with the head or head gaskets.
Old 03-20-2007, 07:07 PM
UncleBob UncleBob is offline
AF -Advisor
how do you know the t-stat is good?
fans come on when they should?
you've removed the water pump and inspected it?
tested the radiator cap? Or just replace it.
Radiator is flowing well? Tested?
life begins at 10psi of boost
Three turbo'd motorcycles and counting.
Old 03-20-2007, 07:10 PM
HeavyJ HeavyJ is offline
2 different shops....what did they do, just stare at it? they should have at least done a pressure test on the cooling system, pulled the plugs and looked at them and I usually pull one of the valve covers and look for sludge coolant contamination. Did they look at the trans fluid for contamination? A compression test or better yet a leakdown test needs to be done.
Old 03-20-2007, 07:16 PM
AF -Advisor
if you were burning 3/4 of a gallon of coolant in 12 blocks, you would have such a large white cloud coming out of the exhaust, you wouldn't be able to see 5 feet infront of you
Either some of the info isn't accurate, or you have a very odd deal.
Old 03-20-2007, 07:23 PM
3/4 of a gallon every 12 blocks? that didnt register when I read it, yeah they should be trailing a cloud. still 2 mechanics should have found something.
Old 03-21-2007, 08:01 AM
I took the thermastat out and it still overheats. no steam out of the tailpipe when its running. Both mechanics said the waterpump is fine but Ive lost confidence. How wold one check a waterpump?
Old 03-21-2007, 08:08 AM
It has a new rad cap. Pressure tested fine. both fans come on. i don't think they went as far as to pull the valve cover but sounds like I may need to
thanks
Old 03-21-2007, 08:45 AM
AF -Advisor
for humors sake, I'd pull the waterpump and check the impellor. Many cars these days use plastic impellors, and sometimes they shatter. What you're discribing, it very well could be that
Old 03-21-2007, 12:02 PM
GreyGoose006 GreyGoose006 is offline
waterpumps are actually not hard to change.
the actual process is simple. un bolt it and put another one on.
the hard part is gettign to the pump, as it is ususally buried under 3-4 layers of accessories on the front of the engine.
