Go Back   Automotive Forums .com Car Chat > Honda > Civic | CRX > '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV
Old 03-20-2007, 02:36 PM   #1
asucivic
????????????d15bvtec?????????
i have a 95 civic ex with the d16z6 and it is blown i was wondering if i could use the tranny from it and all my other stuff like ecu and mounts for the d15bvtec, or what other stuff i might need??????
asucivic is offline   Reply With Quote
Old 03-20-2007, 03:20 PM   #2
typerx7
Re: ????????????d15bvtec?????????
everything except for the ecu will transfer over. There will be a few wires that wont conenct to the engine from the harness. Im not so sure that the D15 has a vtec model, but correct me if im wrong.
typerx7 is offline   Reply With Quote
Old 03-20-2007, 04:12 PM   #3
CivicSpoon
There is no Spoon
CivicSpoon's Avatar
the d15b vtec is a jdm engine, it does really exist.
If your d15b has a vtec pressure switch, then your existing ecu will be fine. Other wise you need to put the one from your original engine onto the d15b, to use your existing ecu. The rest of the parts will all be the same as your original engine (mounts, transmission, wiring harness, O2 sensor, distributor, etc).
CivicSpoon is offline   Reply With Quote
Old 03-20-2007, 06:26 PM   #4
jbluesi
jbluesi's Avatar
it is a direct replacement engine, i have one in my hatch. hauls as$ for a 1.5L
jbluesi is offline   Reply With Quote
Old 03-22-2007, 09:56 AM   #5
aerosoul67
im a begginer in this field. i hve a d15b engine and i want to modify it for illegal drag racing w/ my friends. what should i do to improve the speed w/o the headworks. i hve installed racing filter, headers (4-2-1 although they say 4-1 is better in drag), and adjustable cam gear. any ideas what to do next to add up hp? tnx.
aerosoul67 is offline   Reply With Quote
Old 03-24-2007, 07:41 PM   #6
KoHC
Just a question, why not go for better engine (B16A or others)? D15B VTEC doesn't produce that much more horsepower (130hp compare to your old 125hp).
If it's the price (I'm sure it's cheaper than B16A), then you shouldn't need much changes. AFAIK the wiring harness is on the different side (JDM) so you might need to re-route some of the wires.
By "illegal drag racing", I hope you're not referring to the movie "Gay and Hilarious" style driving.... Also, don't do any street racing, unless you're willing to risk losing your license and maybe your own life.
Anyway, do you have stock U.S. D15B engine? Any idea which one? If you have '91-'95 Civic CX, your engine only produce 70hp. So any mod you put on the engine won't help. Just get an engine swap.
KoHC is offline   Reply With Quote
Old 03-24-2007, 08:24 PM   #7
CivicSpoon
There is no Spoon
CivicSpoon's Avatar
No need to use the d15b vtec wiring harness, the EX one will work fine, especially when using the stock ex ecu.
