Old 03-20-2007, 01:33 PM
cef2lion cef2lion is offline
Thermostat housing
When replacing the thermostat on my 2000 Intrigue. Is it suggested to replace the housing at the same time or are they sold that way. I know about the enhanced thermostat part number. Is it best to get this at a GM dealer so you know you got the enhanced thermostat?
Craig
Old 03-20-2007, 08:53 PM
atoyota4x4 atoyota4x4 is offline
Re: Thermostat housing
Its all one piece. Dealer part will run you around $60 or retail parts store should run about $30. I went with local retail (NAPA). Either will work.
Old 03-21-2007, 08:45 AM
8bahead 8bahead is offline
my enhanced thermostat was $162.00 from a local GM dealer most part houses here are $128.00. The enhanced thermostat housing differs from the regular thermostat housing,the enhanced housing fits almost flush with the engine block. OEM housing is almost a square box. The enhanced thermostat solved my overheating problems,with a round trip from cleveland to alantic city just completed,I had no over heating issues....Good Luck!
Old 03-21-2007, 08:48 AM
Wonder if someone like NAPA would have the enhanced thermostat or that is a dealer only item?
Craig
Old 03-21-2007, 01:19 PM
dtownfb dtownfb is offline
Also try www.gmpartsdirect.com. They are normally cheaper then the dealer.
