Go Back   Automotive Forums Car Chat > Dodge > Daytona
Old 03-20-2007, 12:04 PM
drgreenthumb drgreenthumb is offline
Had my mitsubishi turbo putting out 20 lbs. of boost!
I had an 89 chrysler lebaron 2 door convertible-2.5L turbo, and now I have a 90 daytona 2.5L turbo and I had both turbos putting out 20 lbs. of boost without over boosting or extreme modifications.
When I had it putting out 20 lbs. my buddy with a 5.0L mustang gt told me he would be hard pressed to beat me. I took him for a ride and pinned him to his seat.
I messed up vacuum lines and had the wastegate blowing wide open while the computer thought there was no boost. These turbos can put out 25 lbs. max. I'm gonna try and recreate what I did before, I'll keep everyone posted. I also have an intercooler out of a pt cruiser I'm going to drop in soon. Does any one know where I can get cheap intercooler piping?
Old 04-09-2007, 07:06 PM
93_R/T_TT_Stealth's Avatar
93_R/T_TT_Stealth 93_R/T_TT_Stealth is offline
Send a message via AIM to 93_R/T_TT_Stealth Send a message via MSN to 93_R/T_TT_Stealth Send a message via Yahoo to 93_R/T_TT_Stealth
Re: Had my mitsubishi turbo putting out 20 lbs. of boost!
what exactly did u have to do to manage this working without roasting your engine? gettin 20 psi outa a 2.5 T?
93' Stealth R/T Twin Turbo Intercooled - 24v DOHC 3.0 v6 engine - AWD AWS - 320 hp 317 lb ft. torque when I bought her unmolested hoping to be in the 600-700 hp when finished with ...
~FASTER THAN A SPEEDING TICKET~
Old 04-10-2007, 12:47 AM
I think the vacuum lines to the wastegate solenoid were blocked off , and the lines off the waste gate were rigged into the brake booster lines. so the computer thought the turbo wasn't putting out any boost and the vacuum was just blowing the waste gate wide open. I reached twenty at the max, these turbos are rated for 7 tops, but can put out upto 25 psi.
The bottom and top end were rebuilt so it handled it well, but I had a slow oil leak and before I knew it I was cruising on the highway at 3000 rpm with no oil pressure. Threw rod bearings, blew a gasket and more, but it's running ok now after much hard work. I just have to recreate the vacuum line mistake.
Old 04-17-2007, 02:06 PM
Jimbobbubbajoe Jimbobbubbajoe is offline
You'll want to be careful or your motor will end up looking like this.
http://www.fourcylinderracing.com/in...=26&topic=19.0
Old 04-26-2007, 10:12 PM
Polygon's Avatar
Polygon Polygon is offline
The Red Baron
Send a message via MSN to Polygon Send a message via Skype™ to Polygon
Well, you've got two problems here:
1. The stock fuel system can't keep up with 20 PSI.
2. Running that much boost on a little TE04H, especially without an intercooler is just asking for problems.
Both of these are going to cause detonation. These engines are stout and can handle well over 20 PSI but, just like any other engine, they can't handle detonation especially at WOT.
Old 03-18-2009, 08:30 PM
92IROC 92IROC is offline
let me know what you messed up, take some good photos...and notes
