Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 03-20-2007, 10:40 AM
bdela005 bdela005 is offline
Angry 98 gsx squeek when downshift
so i have a 98 gsx... Bought 4000 miles ago. 115000 miles on it now. In those 4000 miles i have replaced sooo many parts including a clutch, starter, belts gaskets. ect. But my new issue is when i downshift to slow down not to pass, there is a squeek coming out of my car. almost like a whistle. i have no idea what it is. When i back my car up it sounds like the drive shaft might be squeeking a little bit also dont know if these problems are related... SOMEBODY PLEASE HELP this car is becoming a money pit
Old 03-20-2007, 11:21 AM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Re: 98 gsx squeek when downshift
Ha ha... well man, DSM's are known for eating money. However, I dont think your problem is a problem at all. Sounds to my like its your BOV dumping. If its louder its possible that the dump tube came off and is venting to atmosphere, but nothing bad can really happen from that.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 03-20-2007, 11:39 AM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Also may be just a little boost leak. Something may not be clamped down 100% or even may have a small pin-sized hole somewhere. But check the BOV first.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 03-20-2007, 07:20 PM
scottsee scottsee is offline
Send a message via AIM to scottsee
I thrink its your fuel rail, time to change the fuel rail filter, your getting back wash..
DSM geek
Old 03-20-2007, 08:04 PM
crunchymilk55's Avatar
crunchymilk55 crunchymilk55 is offline
Send a message via AIM to crunchymilk55
are you kidding?
now - 2000 civic
soon - 2002 is300
Old 03-20-2007, 08:41 PM
Mad tight venting Yo!! Who needs accurate HZ signals anyway. Call it.... Knock prevention..
DSM geek
Old 03-21-2007, 03:36 PM
i got a chance to really listen to it today backing up and downshifting with the door open sounds like its coming from center of car...
MAYBe the drive shaft?? im going to get it onto a lift this weekend and try to spot the noise thanks for the replys
Old 03-21-2007, 06:30 PM
bdela005,
you have what's called the "dsm squeal" at least in some circles. It is totally normal, our cars are old, they will make noises. It's nothing to worry about. If it only squeaks when you are downshifting, then be happy, because you can be 100% sure you are driving a real dsm
now - 2000 civic
soon - 2002 is300
