Old 03-19-2007, 10:27 PM
351wStang's Avatar
351wStang 351wStang is offline
Latest progress on my street car.
Well today I finished welding in my Wolfe 10-point ms roll cage. The cage is legal to 8.50 seconds in the 1/4 mile. I've got pictures of the cage just before I finished it. I added 1 bar above the windsheild and 2 bars going from the main hoop thrue the floor to the subframes after taking the pics. Also last week I installed a QA1 k-member, along with new power steering rack & pinion, pump, hoses, tie rod ends, and ball joints.
1969 Cougar
357w & TKO - 475hp
Old 03-19-2007, 10:30 PM
351wStang's Avatar
Re: Latest progress on my street car.
I'll try to get pics of the finished product up later this week. My B&G turbo kit shoud be here this week as well.
1969 Cougar
357w & TKO - 475hp
Old 03-20-2007, 03:51 PM
SkylineUSA's Avatar
SkylineUSA SkylineUSA is offline
Send a message via AIM to SkylineUSA
David,
Nice work man! Your sticking with the F303 for the turbo, right? What tubing are you using? Are you using a MIG to install?
Time to change your sig
R32 GTR w/351w .020 forged, 8.9:1, PTK T76, Turbosmart 40 BC & 45 WG, Tial 40 BV, AFR 205s 310/245, 228/228 550/550 114 Hydro, 1.7rr, Isky RLs, 4" HKS exhaust, ARC 30x16x4 IC, 8 point cage, C2 gauges, 2 step, C4 3200 stall w/ R Manual & Hurst Ratchet shifter, 17" Panasport G7s, CSU 750 & bonnet, Vic Jr intake, 3.63 gears, Corbeau Carrera seats, Custom wide body, Bomex side skirts and rear 1/4 caps, Tommy Kaira bumper.
Old 03-20-2007, 11:16 PM
351wStang's Avatar
Yep keeping the F303 and 1.6 rr's for the turbo. The tubing is just mild steel. Its the Wolfe Racecraft 10-point cage kit for a fox coupe. I payed the extra bucks to get it jig notched so I could just hold & weld lol. A few things I would have liked to do different but overall its not bad for my first roll cage install. Also yes its just mig welded in there. I bought a Hobart Handler 140 I beleive it is. Good enough for mild tubing and sheet metal (mini-tub), chassis work. I'm gonna wait to get the turbo installed before I change my sig. Dont wanna jinx myself . Turbo kit shoud be here any day now.
Thanks for the props Tony!
1969 Cougar
357w & TKO - 475hp
Old 03-27-2007, 01:55 AM
351wStang's Avatar
Well I've got some more pics, just gotta upload them.
But, I finished painting the roll cage today, got the carpet back in, and the fuel cell back out. I'm having aluminum -AN fittings TIG welded to the fuel cell. The bulkhead fittings with the nylon washers I used last year leaked bad. Also after installing the QA1 k-member and reusing the stock control arms the front tires are way forward. So far that when I turn the wheel all the way they actually hit the front of the wheel well. To hell with that, QA1 tubular control arms and Strange coil-overs are in the mail. B&G called me last Friday and said they shipped my turbo kit so it should be getting here this week. I've been waiting 11 weeks for it, they told me it should take 5-8 weeks. But, at the same time I do understand that this was a custom build, they didnt have to car to work off of, they just had my measurements lol. They charged me pretty much their regular price too so I cant complain. Nobody else will have a kit like mine lol. 700rwtq @ 3500rpms here we come! (I hope )
1969 Cougar
357w & TKO - 475hp
Old 03-27-2007, 10:01 AM
SkylineUSA's Avatar
700 @ 3500, are you sure about that
Old 03-29-2007, 12:28 AM
351wStang's Avatar
It should be all in by 3500-3700rpms. I'd say if I made 485rwtq with the blower and blown headgaskets I should be pushing another 200 easy with the larger turbo. The numbers in my sig where actually made with 11psi, lost 3psi when the hg's blew. Also at that time I had the boost guage plumbed to the carb hat so the motor may have been seeing a little less than the guage showed. I ordered the wastegate with a .8bar spring which is advertised to hold 11.6psi. I figure I'll probably see 12psi or so on the boost/vacuum guage (plumbed to the intake). Also I added an air/air intercooler this time so cooler IAT's will help as well.
1969 Cougar
357w & TKO - 475hp
Old 03-29-2007, 01:23 AM
SkylineUSA's Avatar
That is going to be a handful!
Old 03-29-2007, 08:13 AM
351wStang's Avatar
1969 Cougar
357w & TKO - 475hp
Old 03-29-2007, 09:50 PM
fordtrucksonly's Avatar
fordtrucksonly fordtrucksonly is offline
Looking good man, love to see some more pictures! Great job!
-chris
"When Lightning Strikes the Heartbeat Stops!"
'91 Mustang LX 347 StRoKeD & BlOwN
'04 Ford F-250 6L PS FX4
'95 Ford F-150
Ford Racing Pride
General Motors who?
2004-2008 Ford Master Certified Technician
Old 03-30-2007, 10:47 AM
351wStang's Avatar
Thanks Chris!
The turbo kit has arrived! But my motor mount wont be here until Monday..
So it looks like a thrash next week to get the motor in the car and get her up and running/driving by Easter weekend! I better get to work.
1969 Cougar
357w & TKO - 475hp
Old 04-05-2007, 01:20 PM
351wStang's Avatar
Well good and bad news. The motor mounts finally got here, thursday. They where supposed to be here with the turbo kit last week but they didnt ship them for some reason! Also I still have not recieved my silicone couplers and t-bolt clamps for the cold side plumbing! I also have to send the boost ref power valve in my carb back to CSU to change the seal. The manufacturer CSU had been buying pv's from changed material on them and they have been tearing under boost. This causes you to go lean, the power valve doesnt work when the seal is torn. Also I have to get an appointment to get the car aligned because I installed a new rack & pinion, tie rod ends, ball joints, k-member, control arms, coil-overs, and caster camber plates. So basically the front of the car is all out of whack right now.
I do have the motor set down in the car now, its a little after 2pm and the motor mounts got here just a few hours ago. Bad news here is I have to order an aftermarket tranny dipstick, the stock one wontn work because the downpipe has to go right where the dipstick is. So basically I wont get the car on the road this weekend like I had hoped! Damn if people would just ship what they are supposed to ship when they are supposed to ship it I might have been able to get the car going, take it easy on the power valve and get to the alignment shop this week, then overnight the powervalve and have it overnighted back. Then I could have made my deadline.
There is alwaysnext week I guess...
1969 Cougar
357w & TKO - 475hp
Old 04-05-2007, 04:41 PM
SkylineUSA's Avatar
You can align your car with kite string That is how I do mine.
Old 04-06-2007, 10:26 AM
351wStang's Avatar
I thought about that, I'm just tired of screwing with tie rod ends lol.
Should get new pics up in a day or so.
1969 Cougar
357w & TKO - 475hp
Old 04-06-2007, 10:35 AM
SkylineUSA's Avatar
Cool
