Go Back   Automotive Forums Car Chat > Mazda > 323/Protegé/Familia/Etude/Allegro
Old 03-19-2007, 09:47 PM
robertpreuss's Avatar
robertpreuss robertpreuss is offline
Send a message via Yahoo to robertpreuss
failed emmissions
1989 mazda 323 1.6 5spd failed emissions twice..........suspected egr valve can't find egr valve?if not egr valve what else could be.......replaced plugs,a/filter,f/filter,oil & filter,cat convertor think its 2yrs anyone greatly apprecheated,robert.
Old 03-21-2007, 09:25 PM
protegeinde protegeinde is offline
Re: failed emmissions
heres what i would try..get a can of sea foam run it through your vaccum line should be the thicker line next to your brake booster. basically run 1/3- 1/2 the can through that vaccum you will need to keep the throttle around 2500-3500 rpms or its going to stall...next dump 1/3-1/2 into your gas tank this will clean your injectors..the point of the vaccum line next to the brake booster its going to clean out the top end of the motor ( egr valve ) this may or may not due it but its 6 bucks and you cant screw anything up.
for any more information on this please feel free to stop by www.clubprotege.com theres many how to's and write up on this procedure
Old 03-30-2007, 04:28 PM
Doug Tatham Doug Tatham is offline
The egr is on the back of the engine, drivers side behind the throttle body. It's a bit hard to get to. They tend to clog with carbon deposits and can stick open or shut. If this doesn't fix it, there may be a problem with your catalytic converter. Ask the emissions testing place if they have a suggestion.
Old 04-01-2007, 09:51 AM
emissions
thanks for the help fixed egr valve and went through great thanks again for all the help much apprecheated.
