Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 03-19-2007, 08:08 PM
mike561 mike561 is offline
Blower motor resistor
How can you visualy tell if your blower motor resistor is bad other than the high speed only working???????????
2006 Chevy Cobalt LS
Old 03-19-2007, 09:37 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: Blower motor resistor
If the high speed is working, then chances are the motor is fine. Look to the resistor grid - chances are the problem is here or in the control switch.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 03-19-2007, 10:03 PM
I think i just need to get a voltage meeter to test the voltages comming off the resistor and speed switch
Old 03-28-2007, 05:11 PM
I went to bennet auto supply today to get a brand new blower motor resistor. i put it in and it still only works on high, then i tried a different switch on the ac control as well, still only works on high. go figure, its probably a more technical problem now isnt it? i dont even know where to start looking around. i dont want to have to take it to the shop unless i REALLY have to.
Old 04-11-2007, 09:10 PM
randy78 randy78 is offline
Send a message via Yahoo to randy78 Send a message via Skype™ to randy78
well thats about impossible, the only culprits can be the resistor springs or the fan speed switch, theres nothing left
the motor is fine if it works on hi
on hi position neither of the resistor springs are used
hi is direct vltage not resisted
i would clean and dry the connectors, must be dirty and corroded
use electrical cleaner spray on them
see if they are dirty or green
wiggle the connectors around with it on lo or med setting
good luck
I also am user fastr68 here- Randy
-'54 F100 302 C-6 -'57 F100 -'57 Bel Air HT 307 4spd '57 210 HT 4dr 265 3spd -'68 corvair monza convertible w/ PG -'79 C-20 -'80 K-20 -'82 K-10 SS -'82 TRANS AM WS7 HT 5.0L TH350 2400 stall blue/blue level III PMD cloth PG hood -'85 Elky SS 310ci 2004r fully restored 2008 -'88 buick century estate wagon 3800 4t40e, 91 s-10 2wd 4.3L, 96 taurus, '97 cavalier RS 2.2L, 5sd -'05 18ft car trailer, 98 achieva, 98 cherokee,
