Old 03-19-2007, 08:33 PM
Slatcher Slatcher is offline
car problems
so the other day im crusin down the highway in my 91 civic cx, then suddenly the engine light came on and the tach kept showing that rpms were droppin to 1000 to 500 then jumping back up to 3000. so i pulled over.....etc, etc....
after doing a compression test which checked out ok i noticed the the cylinder nearest to the driver's side was pumping out quite alot of gas, and there is a loud lifter clickin away. oh ya there was oil in the sparkplug well second one in from the passenger's side
im baffled, what have i done to my car?
Old 03-19-2007, 09:27 PM
CRXperiment's Avatar
CRXperiment CRXperiment is offline
Re: car problems
Does it still run? Is it just that the rpms fluctuate all the time? It would really help if you told us the code it was throwing for the check engine light. Lift up you passenger carpet, turn your key to ON and count the number of blinks your ecu lets out. I'm willing to bet its a code 14 for you IAC valve.
Here's more info on what i mean:
http://honda-tech.com/zerothread?id=468260
1989 Civic STD - sold
1991 CRX Si - current
Free Service Manuals: http://hondatech.info/
Old 03-20-2007, 09:21 AM
Re: car problems
ya the car still runs but really rough as in i can't drive it i sounds like it misfiring real bad on one cylinder. ill go check the ecu light tonight thanks for that i had no idea about that
Old 03-20-2007, 09:33 AM
Re: car problems
o ya and the engine misses throughout driving range speeds, i found that out while tryin to get off the highway
Old 03-20-2007, 05:30 PM
Re: car problems
huh after replacing all of the seals and using a stethoscope to listen i found the the core problem was the distributor. the little plastic wheel has worn all to hell and feels loose but i can get it to come off.
so im just wondering how to remove it.
Old 03-20-2007, 08:03 PM
Re: car problems
Do you mean the rotor? Sounds like the rotor screw got loose and caused the rotor to get loose. Take out the screw and fit in a new one, this time put loctite on the treads to make sure your rotor is on there tight. BTW this is a common problem.
Old 03-20-2007, 10:06 PM
Re: car problems
ya i ordered a new rotor because the old one was screwed, i will loctight it down thanks for the tip
and thanks for the help
